Don's Bolt's Engine
Old Mar 24, 2002 | 02:05 PM
  #31
Hamma's Avatar
Don be sure to let us know when your going up to NE Dragway. I will need to check it out
Old Mar 24, 2002 | 03:48 PM
  #32
tallimeca's Avatar
me too
i hear ya hammer. Definetely wanna see some results after hearing all the hoopla HDMILNIUM has some tricks up his sleeve too I hear. Don vs. Bill.....the showdown.
Old Mar 25, 2002 | 01:11 AM
  #33
Blown00''s Avatar
it may just be Don vs. Bill vs. me if i have my way.... i got 15 grand layin around to spend hmmmmmmmmmmm........
Old Mar 25, 2002 | 10:01 AM
  #34
LightningTuner's Avatar
Originally posted by Don's Bolt
It is still not done, I talked to Jim this morning he tells me he is priming the motor and should be starting it this morning.
I could be wrong, but I'm pretty sure you can't prime a modular motor. The oil pump is driven off the crank snout. You'd have to actually spin the motor to get oil in there, and at that point I don't think it's really "priming" .
Old Mar 25, 2002 | 02:07 PM
  #35
LIGHTNINROD's Avatar
Slightly off-topic..............
Reading Sal's post about "not priming" made me think of what some guys have said about how they do their oil changes. I'm talking about those that "hold the gas pedal down while turning the ign. key 'on' to prime the eng." as the last step in an oil change. They try this(along with pre-filling the filter--I believe in this) to keep from getting "unusual noises" after an oil drain/change. My point is, I don't think a battery and starter can spin the eng. fast enough to build up enough oil pressure to do any good.
Sal, am I wrong ?
Dan
Old Mar 25, 2002 | 02:49 PM
  #36
RTKILLA's Avatar
Don I feel for you brother!
All I can say is that its going to be worth it. I know my tranny will be!
Old Mar 25, 2002 | 04:36 PM
  #37
easterisland's Avatar
How about an accusump?
Old Mar 25, 2002 | 04:37 PM
  #38
Don's Bolt's Avatar
Thumbs up
Hey dudes
I went to NJ to check it out today, went to see the motor being set up on the dyno, I guess I misunderstood what Jim told me the other day.But me is feeling so much better now.
Old Mar 25, 2002 | 04:57 PM
  #39
RTKILLA's Avatar
Hey dudes
I'm guessing you mean your motors not in your truck yet, but its running good. Well I guess thats close then?
Old Mar 25, 2002 | 05:45 PM
  #40
Fast Gator's Avatar
Hey dudes
I feel better knowing you're feeling better
Old Mar 25, 2002 | 06:55 PM
  #41
kidtriton's Avatar
Sals not saying that the starter isnt spinning it fast enough for oil pressure. The true purpose of "priming" is to run the oil pump and circulate oil without the pistons moving up and down, crank turning, cam turning etc... Having to spin the crank in order to "prime" the pump doesnt accomplish this.
