Burnout help.
Old Mar 8, 2002 | 12:36 AM
Jay Lincoln's Avatar
Burnout help.
Ok you experienced drag racers, figure this one out. I was practicing my burnouts this evening, since the track was rained out. And I have a dilemma.
My truck will NOT upshift out of first gear while I am doing the burnout. I tried it with both my foot on the brake, and off the brake, with the same results.
Am I missing something? I can get only about 40 MPH wheel speed before the truck hits the rev limiter.
Old Mar 8, 2002 | 01:28 AM
ICULOKN's Avatar
Jay,
Have you tried to manually shift during a burnout? Sometimes I put mine in First and go to have throttle, then shift to 2nd and hit it to make it burnout to the line. I have even done a burnout in only 2nd and had good luck with that as well.... 1.69 - 1.75 60 foots on stock stall convertor!!
Old Mar 8, 2002 | 01:44 AM
thepawn's Avatar
I dunno, on the street earlier I did a slight brake induced burnout and easily shifted while spinning..
Daniel
Old Mar 8, 2002 | 07:49 AM
LIGHTNINROD's Avatar
JL:
I have the same problem??? Sometimes I get a good burnout but sometimes, it doesn't upshift--probably me?
Dan
Old Mar 8, 2002 | 07:52 AM
Lightning Boy's Avatar
Try checking with swanson.... He might be able to help you.
Old Mar 8, 2002 | 09:48 AM
Thanks for the help guys.
Richard, I did try to shift manually, but it didn't help. Also, it will do a burnout in 2nd, but Greg Evans said that wasn't too good for the trans.
I am going to install the Factory Tech valve body, and then have Danny Swanson return the trans pressure back to stock on the chip. Maybe that is the problem.
Old Mar 8, 2002 | 09:56 AM
BLackBoLT99's Avatar
Suspended For Rules Violations
Hey Jay, still having a problem with this? Just give the truck to me, I'll show you a burnout you'll never forget!!
Hope things work out for you.
Old Mar 8, 2002 | 10:07 AM
walker887's Avatar
Jay when I raced FFW in my Saleen with the C-4 I would only shift into second toward the end of the burnout, it really isn't good , cause that is when it really starts to hook, At a 40mph wheel speed I think the Slicks are hooking really good. it doesn't take alot to get a Mickey or Hoosier to hook anything more is wasting your tire. I had a set of goodyears that I could not get to hook at all. needless to say I will never buy them again. I always did a heatup and then a dry hop and was ready to go . pulling 1.49's and they lasted 12 races at probally an average of 8 or more passes a race. and if they are hooking that good make sure you screw them.
Don
Old Mar 8, 2002 | 11:05 AM
Black Bomber's Avatar
These trannys are bullet-proof!
Old Mar 8, 2002 | 12:34 PM
D_Coburn's Avatar
Don
Isn't this a little off topic??
Old Mar 8, 2002 | 12:38 PM
walker887's Avatar
LOL, At least it is safe
You all know what I mean , but I never really thought of it until you single that phrase out LOL
Old Mar 8, 2002 | 04:23 PM
Don, yes, I can get the tires good and hot at 40 mph. It takes about 6-7 seconds. I did about a 10 second burnout last night, and the street was full of smoke and rubber. The tires were hot too.
The Street Legal Drags people get funny if you go over 5 seconds on your burnout. I guess they'll have to get funny. After the first heavy burnout, the ET Streets probably won't need much on subsequent burnounts.
Old Mar 8, 2002 | 07:55 PM
Neal's Avatar
Cool
HI!... Here's one I did a while ago. Most of you guys have already seen this but I'll post it again for the newer guys. This was done in 1st gear and you can hear me shift into 2ND gear. The truck bogs sightly during the 2ND gear shift because I was stepping on the brakes real hard to keep the truck from lunging forward. This is about 52 seconds long. By the way I'm N/A naturally asperated.
http://www.85merk.com/movies/Neal_Massive_Burnout-s.mpg
Old Mar 9, 2002 | 12:15 AM
kidd2001's Avatar
Talking
Old Mar 9, 2002 | 01:26 AM
Intel486's Avatar
Neal.... WHOLY!!!!
I wish my truck could do that. DO you ever do that at a redlight
I've got a question. When you do this you have to hold down your brakes... Hard. How do you keep from blowing out your back breaks?
