HELP! Tonneau Cover Question
Old Mar 4, 2002 | 08:12 PM
PWR_WHLS's Avatar
Question HELP! Tonneau Cover Question
Tonneau < -- spelling? don't know
Anywho- I've never had to remove my tonneau cover before - it's the Ford brand (the only option that is available)
Anyone know how to remove the thing???
I noticed that their are some spring loaded latches underneath, but they don't seem to butch too much... afraid I'm going to break something
Please HELP
Thanks everyone
John
Old Mar 4, 2002 | 08:29 PM
NozeBleedSpeed's Avatar
Those are fixed brackets.Back out the bolts with an allen wrench and the brackets and rails will come right off.
Old Mar 4, 2002 | 09:38 PM
Did you get it off?
Old Mar 4, 2002 | 11:58 PM
PWR_WHLS's Avatar
YES!! - Thanks so much. I'm moving; just a few miles down the road to my house (i'm happy to say i'm a first time home owner!). I needed the bed space <-- as much as I hate to use the L for hauling. Luckily, it was only boxes; so no scratches.
I didn't realize once the 'tension bars' <-- (if that is what you wanna call them); were released all you had to do was 'peel off' the tonneau! Duh! I feel dumb.
Again- THANKS SO MUCH. I was VERY afraid of breaking something. The cover rolls up nice and neat - very cool design.
Take Care,
John
Silver 01 (a.k.a. "PWR_WHLS" )
Old Mar 5, 2002 | 09:14 AM
Silver01's Avatar
PWR_WHLS, if you're talking about removing the Tonneau Cover, then lower the tail gate, attached to the Cover you'll see a nylon fabric loop attached to the cover. Pull back hard on these, one at a time, to pull the plastic lip out of the rail groove. Once the rear has been released, the sides will come out of their grooves easily. Roll up the tonneau as best you can and use the nylon straps at the front of the bed to secure the tonneau. The two support bars are spring loaded into grooves in the side rails. Simply push these to release. The rear rail has the spring loaded latches which you know about, release them and pull the rear rail back to release. Unless you are hauling something that won't fit in the bed with the side rails in place, there is no need to remove them.
