Tranny Fluid
Old Feb 28, 2002 | 10:54 AM
01-Bolt's Avatar
Tranny Fluid
I know there have been alot of question about the factor tech valve body but I have mine and plan on doing the install today(35 degrees). My question is how much tranny fluid do I need for the install. I know i might have to add or in a rare case take some out, but how much should I have on hand prior to the install?
Old Feb 28, 2002 | 11:05 AM
captainoblivious's Avatar
I think it's like 6 1/2? I remember I bought 7 bottles and used most of it.
Old Feb 28, 2002 | 11:30 AM
DB's Avatar
DB
Yep you'll be safe with 7 quarts.
Old Feb 28, 2002 | 11:51 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
heck, buy a case and fageddaboudit. Easier to carry too.
I used approx 9 for the change and the 4x4 pan.
Bob
Old Feb 28, 2002 | 12:24 PM
kylightning's Avatar
how much is tranny fluid?
how much for all --line valve body - pan and fluid (best prices)???
kevin
Old Feb 28, 2002 | 01:19 PM
anyone?
Old Feb 28, 2002 | 03:32 PM
WrongdayJ's Avatar
Valve Body & deep pan from PSP- $250.
A case of Transmission fluid (Mercon, not Mercon V)- $14.
The grin on your face after you install the Valve Body- Priceless!!!
Later,
Old Feb 28, 2002 | 04:22 PM
thanks for the info
kevin
Old Feb 28, 2002 | 04:28 PM
PWR_WHLS's Avatar
I personally am scared to death to put the line valve body in... I heard of people having to replaced their tranny and breaking second gear... is this true.? This seems so common. I would LOVE to be chirp it into second and third!!
If this thing just 'up' the pressure in the tranny, can we also up the tranny fluid pump?
I don't know a whole lot, but I'm trying
john "at work, but not workin"
Old Feb 28, 2002 | 05:18 PM
01-Bolt's Avatar
Just finish the install about 30 min ago. It only took me about an hour to do the complete install and was very simple. If you know how to turn a wrench you can do it yourself. The only problem is it is a little messy but you can clean that up.
My first impressions are WOW!! At half throtle there is a very sharp jolt on the first to second shift. I have not been able to open her up yet because I am waiting on my personalized plate "TRYAGN" but as soon as its on look out. Right now the truck is stock because I wanted to feel the difference between stock and with a 4lb and chip installed.
As far as the amount of fluid I put back in it was 6 quarts. I need to do some driving because I know that it is low.
Old Feb 28, 2002 | 05:54 PM
DB's Avatar
DB
The line mod valve will actually add longevity to your tranny, as it reduces clutch wear. If you get a chip, it would be better to keep the line pressure down electronically and let the line mod valve act mechanically.
There's an interesting write-up on this on www.powersurgeperformance.net/shift.htm by a Ford tranny expert who also sells his own modified valve bodies for the L.
Old Feb 28, 2002 | 08:43 PM
PWR_WHLS's Avatar
Thumbs up
Perfect- thanks DB for the web link. Exactly what I was looking for. Since it's so factory looking, I can't imagine having much trouble with warranty work. Time to pull out the plastic!
Thanks again!
John
Old Mar 1, 2002 | 03:20 AM
Factory_Tech's Avatar
Hay John!
Where are you at, I live in Maineville.
And KYLightning, were you by any chance at the Cracker Barrel last Saturday, I ate there and saw another L in the lot.
G
Old Mar 1, 2002 | 07:22 AM
PWR_WHLS's Avatar
Thumbs up
Hey G - I'm on the west side of Cincinnati, currently in the Western Hills area, but moving next week off Bridgetown Rd. (first home I 'own' :-) )
Right by Nick & Tom's <<---- everyone seems to know where this is!
I haven't joined any L clubs, unsure if I'm going to. Feel free to email me if you have any events I could attend. I don't see to many L's running around my part of town (seen maybe 2?)
Off to Work!!
John
hotelishome@onebox.com
Old Mar 1, 2002 | 10:40 AM
Factory Tech- no i was in Gatlinburg, TN last weekend
01-BOLT-what part on town are you from? what color is your L?
i am very interested in the line valve mod +panand filter, but i am shopping around for the best price right now
do have to get your chip reburned if you do this ???
kevin
