Nitrous Kit
Old Feb 27, 2002 | 12:47 AM
CHIKIN1's Avatar
Question Nitrous Kit
I have a Nitrous Express kit on my Mustang, and it appears to be the same 35-150hp EFI kit sold by a couple of our tuners...My question is "Will this work on my "L", cuz if it will" HEHEHE!!!
Old Feb 27, 2002 | 10:59 AM
CHIKIN1's Avatar
Anybody???
Old Feb 28, 2002 | 03:18 AM
Spade$'s Avatar
Chicken, I too am going for nitrous and from what i've found is that the kit is not exactly the same but it does indeed work just fine. The results are a little less than the wet kits that are now being sold for heavier application (trucks), but the results i've see on a 100 shot where anywhere from 99.8-117hp gains at the wheels.
In short: yes it works assuming that the kit you are talking about is for the 302 mustang
Mark
Old Feb 28, 2002 | 05:37 AM
krzcwby's Avatar
I'm using the NX kit made for fuel injected mustangs, it bolted right in.
Old Feb 28, 2002 | 08:30 AM
mbrown's Avatar
I've used a nitrous kit that was designed for a 84 SVO on my 93 lightning and will be using it soon on my 00. For the most part a nitrous kit is a nitrous kit. There isn't much difference in them until you get in to the high hp applications. Then they use larger solenoids of course. I would definitely call whoever makes the kit and make sure you have the correct jets for your new application.
Old Feb 28, 2002 | 07:24 PM
krzcwby's Avatar
When I installed my Mustang kit onto the L my concern was the fitting for the fuel rail. It turns out they are the same. The other problem was the braided fuel line that came with the kit was too short so I spent a couple bucks and bought a 4foot one.
