Drilling req for Roll-n-Lock, Bedliner?
Old Feb 26, 2002 | 03:12 PM
snoopy's Avatar
Drilling req for Roll-n-Lock, Bedrug?
I'm looking at tonneaus and bedliners. The field is still wide open. Two I'm considering, the Roll-n-Lock and Bedrug, are available at a local dealer. However, he says both of them require drilling holes in the bed to install. Arrgh! Another rusty Ford! I don' wan' no steenkin' new holes in ma bed!
Is this true, or is he just being a Gomer?
thanx.
Old Feb 26, 2002 | 03:17 PM
easterisland's Avatar
You should look into the new pace edwards bedlocker. It is electric cover and the bedrug requires no drilling.
Old Feb 26, 2002 | 03:19 PM
MRBBQMAN's Avatar
i have a roll-n-lock and a bedrug. you have to drill into the plastic side rails, and drill out the plastic wall caps for the exit hoses. no metal drilling
Old Feb 26, 2002 | 03:29 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
exit hoses?
BBQ,
Roll and Locks have catheters?
May have to rig something up to the Retrax cannister/bladder... or something.
Old Feb 26, 2002 | 03:36 PM
MRBBQMAN's Avatar
Wink
yep, just some clear tygon tubing on each side to empty the big aluminum trough, that holds the roll up cover. if the hoses get clogged with , ah,, stuff, you will run about 2/10ths slower or something
Old Feb 28, 2002 | 09:28 PM
J RHT's Avatar
Snoopy,
Like easterisland said.
I got the pace edwards roll up cover for Christmas. No drilling was required. It just uses some aluminum clamps that attach under the bed rail. I was told that drilling would be required when I ordered it, but man was I glad when it came with those clamps.
Not sure if all their covers require drilling or not.
J RHT
