Radiator
Old Feb 25, 2002 | 11:18 PM
L iminator's Avatar
Radiator
Anybody know if it helps to put distilled water in radiator instead of faucet water. Do chemicals in water cause corrosion.
Old Feb 26, 2002 | 04:44 PM
DennisWeise's Avatar
L iminator,
In a closed system like this there is very little evaporation and mineral deposits are minimal. Minerals in water will vary greatly in different areas but there shouldn't be enough to cause a problem. Distilled water is always better, especially for lead-acid batteries. Add a bottle of water pump lube/rust inhibitor and you'll be in good shape.
DW
Old Feb 26, 2002 | 06:30 PM
L iminator's Avatar
Thanks Dennis
Do you know what causes that build-up around the tubes in your radiator?
