15" wheel for slicks without caliper grinding???
Old Feb 25, 2002 | 01:16 PM
superfords's Avatar
Hello everyone, I was just wondering if anybody ever came out with a 15" wheel that would fit and clear the rear discs? It seems like I remember hearing rumors last fall that somebody (maybe Bogart or Weld?) was working on a new wheel that would fit without having to grind the calipers?
thanks in advance for any info.
see you at the track!
later,
chris haynie
Old Feb 25, 2002 | 01:19 PM
LightningTuner's Avatar
Chris, no 15" rim will ever fit on our trucks without some kind of caliper shaving. From the centerline of the axle to the outer portion of the caliper is 7.5", which gives you an overall diameter of exactly 15". In order for a 15" tire to fit on a rim, the rim bead cannot be more than 14.9", and then you still need a little extra clearance between the caliper and rim.
Old Feb 25, 2002 | 02:30 PM
Ebbsnflows's Avatar
How about w/ longer studs and 7/32" spacers?
Old Feb 25, 2002 | 02:38 PM
You'd have to move the rims out about 4 inches to make the calipers not hit.
Old Feb 25, 2002 | 02:54 PM
superfords's Avatar
ok, I just called summit and ordered some 4" extended studs, they should be here in two days.
now which slicks should I buy?
Just kidding
later,
chris
Old Feb 25, 2002 | 04:35 PM
99svtlightning's Avatar
Don't forget the Jeep CJ7 rear fender flares.
Old Feb 25, 2002 | 04:50 PM
Crazyone's Avatar
I 'think' spacers are illegal to run in drag racing. I might be wrong, but i know a guy that claimed he got booted because he was running spacers. Sooo anyone else wanna chime in? ALso i don't think i would wanna run 4" wider in the front, would look like a ghetto ride, and the torq on those studs would be quite substantial.
Brandon
Old Feb 25, 2002 | 07:48 PM
mbrown's Avatar
When I worked at SuperShops we weren't allowed to work on any car that came in with spacers. They lose their torque on the wheel and if your not careful you can lose the wheel going down the road.
