Question About The PSP Nitrous Plate?
Old Feb 24, 2002 | 09:09 PM
HANKFAN's Avatar
I was thinking about purchasing the PSP nitrous plate and was wondering what the advantage would be to use this plate versus just putting the nossle in the intake boot? Also are the screws that come with the plate long enough to allow the use of the oval bore throttle body?
Old Feb 24, 2002 | 09:32 PM
LightningTuner's Avatar
Brian, there isn't a HUGE advantage to using the plate vs tapping into the boot. I designed the plate so people wouldn't have to tap thier boot. However, when spraying from the boot, you are blasting nitrous directly at the throttle body blade, which wastes a bit when it hits the metal. Using the plate, the nozzle is relocated to the corner of the TB opening, and does not hit the blade. It also gets a fairly straight shot right through the intake to the rear of the blower. The supplied screws will work fine with any TB.
Old Feb 24, 2002 | 11:26 PM
HANKFAN's Avatar
Thanks for the info Sal!
