Factory Tech Valve Body!
I'm thinking about purchasing the PSP Factory Valve Body from Sal and was wondering how easy the install is? And also wondering does anyone have any pictures of them installing it? And will my chip need a reburn for it to take full advantage of the valve body?
Thx
-Sam
Thx
-Sam
If you have firmer shifts programmed into your current chip, you might want to have it reburned to stock or at least less firm. The install is easy, though a little messy. The instuctions that come with the part have pics and are easily understandable. You might want to get a deep sump trans pan to go with it, too.
Originally posted by J15BIG
more fluid capacity=cooler transmission
Originally posted by StrikesTwice
: Odin, how much was that pan man? nice rhyme..
Thing is beautiul. I wonder if Rob had one if he would drench it in black paint? Actually, he probably already has
: Odin, how much was that pan man? nice rhyme.. Thing is beautiul. I wonder if Rob had one if he would drench it in black paint? Actually, he probably already has
Here's a link to LFP where you can get one.
http://www.lightningforceperformance...tID=1001-04-02
Originally posted by 99WhiteBeast
Piece of cake on the install. The instructions PSP provides are right on-40 min tops. Replaced my stock pan with the 4x4 deep pan since it has a drain plug
JC
The primary advantage is that it can simply hold more fluid. ATF does break down over time, depending on how hard the truck is run. With more fluid you have a longer interval between required changes. OTOH, it does take longer to reach operating temperature.
I'm sure that's 40 min. for the experienced guy.........for a mechanical idiot like me (aka inexperienced), would you say it's even do-able, or better to take it to someone. I've never screwed around w/a tranny before.
All you do is unbolt the old valve body and install the new one. It goes in the same place with the same bolts.......VERY EASY TO DO--Joe
make sure to buy/rent/use an in/lbs torque wrench for the valve body!!!
--Joe
