Paging Speedin Bob
Paging Speedin Bob
Bob,
Ordered a pillar 3 gauge pod from Lotek and Autometer gauges from Summit Racing. One of the gauges is for measuring boost. Where is the boost line located on the '01 Lightning that I need
to tee into?
to tee into?
VA,
Look and reach under the dash jsut off the right hand side of the steering wheel and you will see/feel a black tube with a 90 degree rubber boot. This is the boost line and where you'll be a tappin.
Head to Autozone, Pep Boys, etc and pick up the following Vacu-tite parts
Part number 47334 (3/16" x 3/16" x 3/16") "T" (2 in the pack)
Part number 47408 (1/8" x 5/32") elbow.
Remove the white inline fitting from the tubing you located previously, install the "T" and elbow(it will be tight), and insert the tube from the gauge.
TEST DRIVE
Here is a pic of the finished product
You can also see where I ran the wires for the other gauges (blue and yellow wires)
You may be able to use the other "T" to make your own boost bypass kit..
Will advise
Bob
TEST DRIVE
Will adviseBob
