Paging USAHOOTERS
Old Feb 23, 2002 | 07:47 PM
CHIKIN1's Avatar
Paging USAHOOTERS
Dude, WTF??? You ran a 7.7 1/8th with less mods than me?
I'll list my mods at the end...have you had your truck dynoed...IT'S STRONG!!!
I ran a 8.19@85MPH w/1.83 60' on ET-STREETS @ 4597lbs!!!
Temp. was around 50-55 degrees.
Black '01
Born on 5-3-01
#3603 of 6381
K&N Box Filter
Sean Hyland Upper Pulley
JDM Boost Bypass
Panhadle Performance/ Autologic Chip
380 RWHP@ Normal Temp.
476 RWTQ@ Normal Temp.
MickeyThompson ET-Streets
JDM Electric fan&CobraR water pump
NGK / BR7 spark plugs
Old Feb 23, 2002 | 07:51 PM
Don's Bolt's Avatar
he has a 3# lower pulley, how many LBS upper pulley is yours?
I bet he has more boost due to the 3# pulley.
Old Feb 23, 2002 | 07:59 PM
usahooters's Avatar
CHIKIN1 no no no no buddy, read my sig. a little closer. My local track is only a 600' track thats 60' short of a real 1/8th. I run a 7.7 at it regularly. I go over to Ms. and run at a 1/4 mile track when I can and only run a 12.62. My best real 1/8 is an 8.1 @ 86 mph. However I am getting 1.83 60' times on F1's. I am running full weight and a 175 lbs bed cover though. What is your best 1/4 time?
Old Feb 23, 2002 | 08:06 PM
CHIKIN1's Avatar
Oh OK, the I see the 600' now... Thanks for the REPLY...Haven't ran the 1/4 in the"L" yet
Don'sBolt, My SeanHyland is a 2# pulley...
Black '01
Born on 5-3-01
#3603 of 6381
K&N Box Filter
JDM Boost Bypass
PSP Longtubes w/Twin Magnaflow
FactoryTech Valvebody (Next Month)
JL 3# Lower (next month)
Old Feb 23, 2002 | 08:13 PM
usahooters's Avatar
CHIKIN1 we need to get together and run sometime. Did you go straight to the BR7 spark plug from the stock ones? I tried them for a while and when I went to the TR 5 I picked up a whole tenth at my 600' track. Just some info. Let me know when you get a 1/4 time.
Old Feb 23, 2002 | 08:20 PM
CHIKIN1's Avatar
I went to the BR7's cause I'm fixin to run more boost and a little laughing gas...they were recommended by my new tuner Sal@PSP!!!
Old Feb 23, 2002 | 08:57 PM
usahooters's Avatar
Yeaup, I would have to agree with that. My 6# pulley should be here Monday. Let me know how your times turn out.
