Cat-Back Question
Old Feb 18, 2002 | 05:25 PM
lightning27's Avatar
Cat-Back Question
Will a cat-back like the new JDM increase or decrease power on a stock L. I've heard that on a un-modded truck, the Bassani cat-back will actually LOSE power. Also, is a cat-back ok for the stock engine without mods. Thanks, also, does JDM sell just a cat-back?
Old Feb 18, 2002 | 05:36 PM
Weedo's Avatar
Struck in AZ put on the Bassani cat back when he was stock and i believe gaine around 7hp and 11tq. If he's here i'm sure he can give you the exact numbers. Cat back is $635 i believe.
Old Feb 18, 2002 | 05:43 PM
Dick 4's Avatar
If you add on just a cat back, they have been known to loose low end. You will get a overall hp and torque gain, but at the sacrifice of low end.
I have been there and done that. You have to get the complete exhaust to gain hp and torque through the overall powerband.
Old Feb 18, 2002 | 05:48 PM
Weedo's Avatar
It completely depends on the vehicle. If you put a better muffler on ANY turbocharged car you'll gain more hp/tq. This is much different than normally aspirated. Supercharged is another story being that it doesn't rely on exhaust backpressure like a turbo.
Now, if you lose torque with JUST a catback, you're losing because a free flowing muffler doesn't have enough back pressure, by putting on a full exhaust, you have MUCH less back pressure so you certainly wouldn't gain with a full exhaust yet lose with just a cat back.
Again, Struck in AZ has the dyno graphs from stock vs. Bassani which will show the increase and where it increases.
Old Feb 18, 2002 | 05:53 PM
Hamrhead's Avatar
My .02, if you install a cat-back on a stock truck, the only thing you should expect is a better sounding exhaust. Wether you gain or lose hp, it will be so little you'll never notice it.
If all you're looking for is a better sound, then make sure to get an open air filter on the end of your mass air meter too!
