Engine Cleaning...
Old Feb 15, 2002 | 11:12 PM
RhinoSlug's Avatar
Engine Cleaning...
and how do you go about it? What do I need to look out for? What cleaners do you use? Do I have watch for electrical connections? Do you use a hose? Any info would be helpful, thanks in advance!
Old Feb 15, 2002 | 11:16 PM
SLVRLTNG's Avatar
RhinoSlug,
I spray mine down with simple green, wait a few minutes and hose it off...then start it wot up and down the culdesac a few times to dry.(j/k about the culdesac part, the rest is true and works great)......JR
Old Feb 16, 2002 | 12:39 PM
slapshot's Avatar
Me too, Simple Green (25% SG and 75% water), spray it all down good, use an old toothbrush to get any heavy stuff off, rinse LIGHTLY, do not use high pressure water. I use a hose about 1/2 open. I start it right away too and drive it to heat everything up and dry it off. To dress it all up, take some Armor All, the plain white stuff, mix it about 50/50 with water, then spray everything down again. I recommend doing this outside and not in the garage, or else you may have a hockey rink on the garage floor. Wife's do NOT like that, trust me. Then just let it all dry again and you have a cleran and shiny engine compartment. I do mine 2-3 times a year.
Old Feb 16, 2002 | 08:35 PM
tallimeca's Avatar
high pressure water
definetely don't use high pressure. I never did and still had two rusty plugs on #7 & 8 when i changed them out......
Old Feb 16, 2002 | 08:49 PM
BlueOvalBolt's Avatar
I used CD-2 Engine Detailer, a 2 can package that has 1 can of engine cleaner and 1 can detailing spray. Very easy to use and the results were outstanding. The only thing I covered were the pulleys and belts, especially when using the detailing spray.
About $7.50 at Autozone.
A great product.
