2" drop spindles
2" drop spindles
Forgive me if this topic has been rehashed many times, but for rhetorical purposes....
Am I correct to assume an alignment is in order after lowering the truck? Can a competent shop get within factory specs?
Finally, do the spindles lead to an early death for the stock rear suspension pieces, if in fact you can retain such parts? Thanks for any information.
Am I correct to assume an alignment is in order after lowering the truck? Can a competent shop get within factory specs?Finally, do the spindles lead to an early death for the stock rear suspension pieces, if in fact you can retain such parts? Thanks for any information.
