Question on Tranny Pan..
Old Feb 14, 2002 | 02:03 AM
SVT-AK-L01's Avatar
I saw a posting not to long ago of a L with a aluminum deep sump pan, was wondering who makes it and where can I get one. My 02 blue will be here next week and I want to install the pan first thing, Thanks for the help
Old Feb 14, 2002 | 02:06 AM
SLICK0478's Avatar
couple companys do
but you can get a for d4x4 pan with the drain plug and it hold 1 extra qt from jdm enginering in NJ or a ford dealer if you can get the part number
slick
Old Feb 14, 2002 | 03:13 AM
J15BIG's Avatar
LFP sells a B&M aluminum pan, thats probly what you saw
http://www.lightningforceperformance...tID=1001-04-02
RA6870's Avatar
Thumbs up
You can get the 4X4 deep tranney pan and filter gasket combo from PSP
http://www.powersurgeperformance.net...28All+years%29
Good luck!!
Old Feb 14, 2002 | 07:14 AM
soap's Avatar
Thumbs up Trans Pan
This is what the ford pan looks like.......
Old Feb 14, 2002 | 07:40 AM
awhittle's Avatar
http://www.hughesperformance.com/perfparts/pans.html
for about $200
http://www.ncs-stl.com/Images/pan.jpg On as stock truck you have 6" of ground clearance
Andy
Old Feb 14, 2002 | 11:09 AM
easterisland's Avatar
Here is a B&M along side a Mag-Hytec. Just from looking at the two I would take the Mag-Hytec over the Hughes and B&M although the price may be a factor. Get a differential cover from Mag-Hytec while you're at it. They look better than a stock rusted out one. They all come with O-ring seals and Stainless steel hardware. You may have to watch the bumps because these pans are deep and you'll have to modify the sway bar if you have a 1" rear drop or more.
Old Feb 14, 2002 | 11:22 AM
RA6870's Avatar
Question
Where do you get a mag-hytec pan and diferential covers from??
Thanks,
Ryan
Old Feb 14, 2002 | 11:55 AM
99 SVT Bolt's Avatar
http://www.mag-hytec.com/
Old Feb 14, 2002 | 12:06 PM
RA6870's Avatar
Thanks for the info!! But what rear end do we have in the 2000 L??
Old Feb 14, 2002 | 12:19 PM
Tachophile's Avatar
Are you guys with the deep pans also lowered?
How much deeper is the 4x4 pan than stock?
I want more capacity, but I also want to lower the truck...maybe 1"/2" What is the best pan? (fit)
Thanks,
-Kris
Old Feb 14, 2002 | 12:35 PM
Dageon's Avatar
Tachophile, you should not have a problem with any pan if you drop your truck 1"/2". You would have to drop it alot more before you bottom out. Dageon
Old Feb 15, 2002 | 12:41 AM
SVT-AK-L01's Avatar
Thumbs up
