Intercooler water pump
Old Feb 11, 2002 | 11:22 PM
krzcwby's Avatar
Question Intercooler water pump
Is the intercooler water pump setup to run only a certain temps? Would it be beneficial to bypass this feature and run it more often?
Old Feb 11, 2002 | 11:24 PM
Lightning Boy's Avatar
When the ignition is on, the intercooler pump is going.
Old Feb 12, 2002 | 12:50 AM
PFA's Avatar
PFA
When you first start the engine, it is not on. After a few, it turns on. You can hook up a switch to turn it on without the motor running though.
Old Feb 12, 2002 | 01:08 AM
J15BIG's Avatar
how would you wire this switch.
Old Feb 12, 2002 | 05:41 AM
PFA's Avatar
PFA
IF, if the SEARCH was working, I could find it. I haven't done this myself yet, but many on here have. Silver 2000 may have it on his website.
Old Feb 12, 2002 | 08:56 AM
99svtlightning's Avatar
There are a couple ways I've seen the wires run. Some attach to a wire near the PCM, which I don't suggest. I ran a switched, and fused 12v wire straight to the pump.
Old Feb 12, 2002 | 06:51 PM
4D THNDR's Avatar
It's on a delayed relay that comes in about 30 secs after starting. If you're gonna wire it to run from a switch make sure you wire it right. Those relays will fry, trust me on that one .
Old Feb 12, 2002 | 07:17 PM
svt360's Avatar
i dont understand the benifit i let the truck run for at least 1 min anyway,and if your at the track sitting what good would it do with out any air flowing thru it??
Old Feb 12, 2002 | 08:13 PM
LIGHTNINROD's Avatar
Probably most guys that do this have a power-cooler and thereby can circulate cooled coolant thru the intercooler. D/k if it would serve any purpose without the 'cooler'.
Dan
