How do I remove Orange Peel?
Old Feb 10, 2002 | 02:09 PM
nostreetracing's Avatar
What is the best way to remove orange peel? Is it something I can do myself or should I take it back to Ford dealer and try to have it done under warranty? Hate to take it to the dealer because they usually screw something else up or it comes out worse than when it went in. Oh, the vehicle is a 02 Lightning silver color. Any help greatly appreciated.
Old Feb 10, 2002 | 02:13 PM
svt360's Avatar
i have a black truck and have the same problem the only way to fix it is to have the whole thing wet sanded and re-spayed with clear,i decided to live with the orange peal
Old Feb 10, 2002 | 02:17 PM
SLVRLTNG's Avatar
I usually just start at the navel and carefully try and remove the peel in 1 piece.......JR
don't you think this is "off topic"????? .......j/k
good luck, probably gonna live with it...
Old Feb 10, 2002 | 02:18 PM
LOL good one SLVRLTNG... Now if I can just find the navel on my L.....
Old Feb 10, 2002 | 02:20 PM
SLVRLTNG's Avatar
my silver '00's navel is located behind the fuel door ....JR
not sure on the '02, but probably it's the same...anyone know??
a little help here
Old Feb 10, 2002 | 02:21 PM
svt360's Avatar
does what i said make sense ????this is what i was told by a couple of guys if i were miss informed let me know so i can look into it further TTT
Old Feb 10, 2002 | 02:30 PM
Fast Gator's Avatar
You might just have to learn to live with it. Unless you want to re-paint the area, then you will have to worry about match Unless you want to paint the whole truck....naw!
Old Feb 10, 2002 | 03:10 PM
1BADTK's Avatar
Orange Peel
Wet sand, wet sand, and buff, buff. Being very careful not to sand through the clearcoat. If you do then it will take some clearing, blending, wet sanding, and buffing again.
Old Feb 10, 2002 | 04:18 PM
trashguy's Avatar
u dont have to repaint just wet sand and buff
i would leave it to a pro cause u can do serious damage to
ur paint if you dont know what ur doing.Also remember
ur taking coats of clear off when u wet sand.I learned to live with mine.
Old Feb 10, 2002 | 04:19 PM
I guess I will just live with it. Thanks to all who replied.
Old Feb 10, 2002 | 04:43 PM
Spike Engineering's Avatar
Why not take it to the dealer? What have you got to loose? If they make it worse, they fix it. If you make it worse, it's your problem.
If they screw up something else, they fix it. If you screw up something else, it's your problem.
Spike
Old Feb 10, 2002 | 05:13 PM
whitetoast11's Avatar
ok ok,,, what am i missig,, i have no clue what orange peel is,, unless you have an orange stuck on your truck, then i have no clue what is being talked about,, can anyone please clarify what this orange peel is ??
~Toast
Old Feb 10, 2002 | 05:16 PM
Boone52's Avatar
ok i am stupid
I know i will hear it for this one, but what is an orange peel?... On a truck.
Dan
Old Feb 10, 2002 | 05:21 PM
trashguy's Avatar
its small ripples in the clear coat looks like an orange peel u know the skin on an orange hence the phrase,its more noticeable in darker colors.
SLVRLTNG's Avatar
Come on Boys,
orange peel is a bad finish on your paint. if you look at it from the right angle it looks like the outer peel of an orange.
The best way to see it is to :
Press your right cheek (pick one) against the surface you wish to view and have a real close looksee!!!...........JR
