ICULOKN (windshield washer tank)
Old Feb 10, 2002 | 11:34 AM
mbrown's Avatar
For those with powercoolers who want to mount them underhood with the battery, here is a option to do as far as keeping the washer tank. Buy washer tank (Ford part # E5TZ-17618-B). Then go to advance and buy a 1 3/8" plug, and a vacuum cap to block off factory holes in tank. You will have to put silicon or glue around the plug to keep water from leaking, if you do this then you will see why. After the glue/silicone has dried then drill a hole directly above the factory hole for your pump. I drilled a 1/2" hole and then dremeled out the rest until the grommet fit. You should be done modding the tank so then all that is left to do, is fit it between your headlight and powercooler. These aren't the best directions but here are some pics so maybe you guys can see what I'm talking about.
Old Feb 10, 2002 | 11:41 AM
ICULOKN's Avatar
Mike,
Do you have a pic of it installed? can you fill it easy?
mbrown's Avatar
There is a small hole inside of the large hole that I plugged with a small vacuum cap. The best place to put your pump is directly above the hole that you plug. I know that its not on the bottom of the tank but it was the only place where the pump would be accesible during the install and also the only place where the pump wasn't being put in a bind.
Old Feb 10, 2002 | 11:42 AM
mbrown's Avatar
Here it is installed
Old Feb 10, 2002 | 11:44 AM
mbrown's Avatar
Its very easy to get to..........I cant believe that I found a tank that worked perfect.
Old Feb 10, 2002 | 11:46 AM
ICULOKN's Avatar
Very nice. You had to tak the headlights out to get it in the right? How did the 01 lights turn out?
Old Feb 10, 2002 | 11:49 AM
mbrown's Avatar
No, just take out the battery and slide the powercooler back and the tank fits flush against the chassis and powercooler. I put the 01 headlights in Friday. Yesterday I put on my driveshaft loop and did this. Kevin(Koochie Krook) came over and we put on a keyless entry pad.
Old Feb 10, 2002 | 11:53 AM
ICULOKN's Avatar
Sounds good man, Are both of you planning on coming next Sat?
Old Feb 10, 2002 | 11:58 AM
mbrown's Avatar
I want to but I'm not sure if I can or not. If my chip gets finished then I'll go no matter what
Old Feb 10, 2002 | 12:01 PM
ICULOKN's Avatar
Come on, You got to!! Plus I need some more BP enhancement!!
Old Feb 10, 2002 | 12:03 PM
mbrown's Avatar
I see how it is now! hahahahaha............well let me go start doing some a$$ kissing and maybe I'll make it.
Old Feb 10, 2002 | 12:48 PM
CrazyFoo's Avatar
mbrown,
are those the Foose Spank's on your truck? The look SWEET!
Old Feb 10, 2002 | 12:51 PM
ICULOKN's Avatar
If it involves your girl, tell her it will be fun!! She seems like a nice girl. Do something for her so you can come man!!
Crazy,
He has Chrome 18in 00 L wheels...
