engine check light?!?
Old Feb 10, 2002 | 03:28 AM
slvrbolt's Avatar
soon engine soon light?!?
what could be causing a service engine soon light? it just came on tonight while i was parked for a while....should i be concerned?
this is what i have done to the truck:
boost bypass
4lb lower
4 way chip
Old Feb 10, 2002 | 08:09 AM
jaymz's Avatar
What have you done to it lately? These damn lights come on for LOTS of things. Mine came on once when I left the gas cap off! Also came on when I left the engine oil filler cap off. So, it could be something easy, simple or stupid. That would be the good part. Mods also cause these amomalies.
Old Feb 10, 2002 | 09:34 AM
awhittle's Avatar
1) Put your key in the ingnition.
2) hold the odometer button down
3) Put your key in the run postion for about 3 sec
4) when your odo says tESt let go of the odo button
5) you are now in test mode. As you now touch the odo button the odo will bswitch to a tach, speedo, test display for engine codes and a few other things.
The Fuel cap loose is the most likely but do not ignore the light. One of us in your area may have a code reader the get a description of the code out of the system.
Andy
Old Feb 10, 2002 | 03:39 PM
slvrbolt's Avatar
ok well it isn't the gas cap. i took that off and put it back on. but i did go through the test menu on the odometer. i did notice one thing that i hope some of you guys can check on your L's hopefully. my oil came up 000. i really don't know anything about how the electrical system works in the L or what the readings should look like. thanks in advance....
Old Feb 10, 2002 | 03:43 PM
ICULOKN's Avatar
I would just disconnect the batt for a few min then try it again. prob just a 02 sensor or something, Do you run fuel additives?
Old Feb 10, 2002 | 03:54 PM
slvrbolt's Avatar
cool i'll try that... i haven't ran any additives but my chip has been giving me hell because of contact problems. i was planning on building up the pcm soon.
Old Feb 10, 2002 | 03:57 PM
ICULOKN's Avatar
Take your battery loose, then make sure the chip is all the way in as well....
Old Feb 10, 2002 | 04:08 PM
LIGHTNINROD's Avatar
Not sure why someone suggested trying the 'test' function without a scanner or code-puller? The 'oil' reading at 000 is 'normal' in the 'test' function--that function doesn't tell you anything but you can get eng. coolant temps, odometer, tach, and speedometer readings while driving with the 'test' function 'on'.
Dan
Old Feb 11, 2002 | 01:57 AM
slvrbolt's Avatar
ICULUKIN nailed it right on the head... i unplugged the battery while at work today and it is all gone now. thanks to all that replied.
