Nitto Tires
Old Feb 9, 2002 | 10:04 PM
Bill Murray's Avatar
Really Old "Member"
Nitto Tires
While I did copy off a bunch of a thread from LightningDammit regarding his replacing his original tires with a particular size of Nitto, I did not accumulate all the info. As the search function is down, I just need a little help.
Basically, I just found out due to a flat on one of my front tires that both fronts are gone. The rears have plenty of tread left, but I want to replace all four at the same time.
About a year ago, LightningDammitt published a lot of pics of what I believe are Nitto 305/55/18 tires he put on his Lightning that were about 31/32 inches in height. Whatever tires they were, these are the ones I would like to fit as replacements for my F1-s. Can anyone verify if that is the size that LightningDammitt fitted to his truck?
Thanks for any and all input
Bill Murray
Old Feb 10, 2002 | 03:42 AM
SILVERLIGHTNING's Avatar
Bill, try this:
Old Feb 10, 2002 | 06:31 PM
Really Old "Member"
SILVERLIGHTNING:
Thanks, that got me the info I needed.
Now, and to really tick some purists off, I am researching if anyone does an 18" wheel similar to the Wheel Vintiques Street Rod Wire Wheel that I could perhaps paint white and with a vintage Ford V8 center cap.
I would, of course, keep the original Lightning wheels for any future owner.
Bill
Old Feb 10, 2002 | 07:40 PM
Masterloggie's Avatar
Bill,
I put the same ones on my truck a year ago. You will need to eithere have your chip reprogrammed or see your friendly svt tech to get your speedometer set for the tires. I initially had the PCM reprogrammed by the tech. The size tires they can reset the PCM to is 6 less revolutions per mile than the Nittos actually are. If mt memory serves me correct the NItto NT 404 305/55/18 are 666 revolutions per mile. The largest size tire (i don't remember the size) that the PCM can be set for is 660 revolutions per mile. If you have a chip the tuner can make it 666. These change a 99 0r 2000 final ratio to about 3:23 and helps with with the gas mileage a little.
I like them a lot, but they are heavy compared to the F1s.
Ron
Old Feb 10, 2002 | 09:02 PM
Really Old "Member"
Masterloggie/Ron:
Thanks for the input. Question, though, do I need to get my chip/chips reprogrammed for normal street use if I do a manual adjustment (brain adjustment) for the speedo error?
I am running a really old Superchip flip chip for the moment which serves me really well. I also have a PSP chip which is more aggressive, also about 2 years old, which I also like but which is a bit harder on the trannie.
If changing to the Nitto's only gives me a slightly false speedo/odo reading, I can live with that. If it screws up something else, it would be good to know. I do realize that it will not accelerate quite as fast as with the FI's and all of that, but as I don't race much anyway that is not an issue.
Thanks for your comments and help.
Bill
Old Feb 10, 2002 | 09:54 PM
dogleg's Avatar
I went with the 404's but then I'm old and I like to see rubber on the sidewall of a truck. Yea, I know it makes the 18" wheels look like 16" but what can I say, I like stripes too.
Alvin
Old Feb 12, 2002 | 03:01 PM
LightningDammitt's Avatar
Doh!
Didn't see this until today...
Yes... 305/55/18's!
I now have 35K on them, and I'm expecting 40K before I change two of them out... This is with very few rortations, and going to the track about once every two months...
I haven't made any changes to compensate, and notice a little less than 10% speed error...
At the track, I've ALways run them at full pressure... 38-30 #'s I believe....
My 60' times improved from 2.0's to 1.9's and a few 1.8's... I'm sure alot of that was due to a learning curve tho.
I think they are an AWSOME tire... but drag radials WOULD give a little more traction.
Also... the extra width COMPLETELY solved the rim dinging problems from curbs and such!
