spark plugs again :)
Old Feb 9, 2002 | 01:40 PM
socallightning's Avatar
With a 3# lower,Filter kit,and a chip. What plugs are the best bang for the buck. NGK tr5 or NGK tr6 , It is a tr5 and not the tr55 right ?
Old Feb 9, 2002 | 01:52 PM
ICULOKN's Avatar
I had the NGK TR6's with that pulley. THen I went to the Denso IT20's. They both worked well. BUt with the IT20's I had better throttle response & idle. If its a money issue get the NGK's....
Old Feb 9, 2002 | 02:21 PM
BlownSVT2001's Avatar
TR6's and 3# pulley are going in today!
Old Feb 9, 2002 | 02:24 PM
HIGH ROLLER's Avatar
Lightbulb
I keep seeing more and more posts about how well everyone likes the TR5 compared to the TR6 which would be 1 range hotter plug, I currently am using the Denso IT20 and runs great with no problems so my question would be is anyone running the IT16 Denso in there truck because that would be running 1 range hotter also and might work out like the TR5 is for some people.Just a thought!
Old Feb 9, 2002 | 02:42 PM
Road Rash's Avatar
I like the tr-5 much better than the tr-6. I guess it depends on your level of mods. The 6's seemed a little to cold for my truck. Whatever plugs are used they need to be checked for proper burn.
Mike
Old Feb 9, 2002 | 03:10 PM
LTNBOLT's Avatar
Cool
Matt,
The Denso site says IT16 for the L. The IT20 is one step colder. The NGK site says TR6 for the L. I'm running TR5's right now and they run almost identical to the Splitfire's. The track opens next weekend and I'll be able to tell you if they turn the same MPH. They burn a good color too.
Don't change the plug according to the tune. Change the tune according to the plug. Tuning to a hotter plug will give you more consistancy with weather changes (humidity and such). Something to worry about down south.
Old Feb 9, 2002 | 03:17 PM
Chuck,
Keep me posted on your results i will be changing my plugs out this spring for the upcoming race season and not sure what plug i want to use this time!
Matt
Old Feb 9, 2002 | 03:40 PM
captainoblivious's Avatar
I just swapped in TR5's this morning. So far it idles good and I'm about to take it out one this beautifull day and test out the new plugs.
These are what my old plugs looked like after 9k miles
Old Feb 9, 2002 | 03:51 PM
usahooters's Avatar
For a daily driver the TR5, I've been down the same road and tried the TR6 and the 103's. The TR5 has much better idle, throttle response and don't foul out from everyday driving. I have the same basic mod's you are running.
