Six Speed
Old Feb 9, 2002 | 10:10 PM
Silver_2000's Avatar
Captain that sounds like a deal at $6000 - Rated to 1300 hp from ProStock use
Drag Racing 5-Speed, Clutchless (#5S-CL)
Manual shifted features latest technology in split-slider design. Pro Stock, etc.
Air shifter has revolutionary solider slider design. Complete for Comp. etc. $6,000.00
Old Feb 10, 2002 | 10:58 AM
Silver-Bolt's Avatar
Hmmm Cobra-R has 5.4. Cobra-R has 6-speed. The T-56 seems to hold up in the Vipers ok also. Not exactly a fly-weight ride.
Old Feb 10, 2002 | 09:04 PM
2000 F150 4x4's Avatar
D&D sells a blueprinted Viper spec T56 rated for over 550 ft-lbs of torque. Price is about $3000. They are for Mustangs, but you may be able to use a bellhousing from the 2001 Cobra R T-56. One of you Lightning guys need to call those guys up. They are THE shop for Mustang trannies.
http://www.ddperformance.com/
Old Feb 10, 2002 | 11:32 PM
captainoblivious's Avatar
2000 F150 4x4 - that sounds like a reasonable swap, possibly something to look into.
Old Feb 12, 2002 | 01:38 PM
RA6870's Avatar
I want at least a 10 speed if i go to a manual !!LOL
Old Feb 12, 2002 | 04:48 PM
svt360's Avatar
i agree with the 4x4 f150 swap the only thing is you would have to use a different gearbox,probly the cobra r
Old Feb 12, 2002 | 07:51 PM
The computer work may get a little tricky. The rest would not be too bad. Pedal and clutch linkage could come out of a F-150 stick or go after market like a Tilton. Clutch, P/P, T/O bearing, flywheel, Cobra-R. Drive line probably custom. Probably have to weld in a cross member.
Old Feb 12, 2002 | 08:00 PM
jabtay's Avatar
i know on another brand truck, you can put the shifter in to nuetral before you take the transmisison out. this will trick the computer into thinking the tranny is in nuetral all the time
Old Feb 12, 2002 | 11:02 PM
jabtay - interesting, but wouldn't that screw something up?
