Is this tru ..?
Old Feb 7, 2002 | 11:44 PM
DaveRed99's Avatar
Is this tru ..?
NOTE: This breather cannot be installed without reprogramming the PCM to compensate for the change in crankcase pressure. If installed without a chip, your vehicle will not run properly.......
Worked oh k on my Ranger.........?
Old Feb 7, 2002 | 11:52 PM
captainoblivious's Avatar
will give you a SES light. I ran my L with the chip pulled and breather on for a little while and it seemed to run fine, but I haven't tried it for an extended period of time.
Old Feb 8, 2002 | 12:44 AM
ICULOKN's Avatar
There is a trick.....
Install a 7/16 Ball Bearing between the PCV valve and the hose it goes into and it will be fine. Or at least thats what I was told to do and I read about it on here. I am going to get my 7/16 tomm!! Got the Oil Breather the other day...
