Directions needed for JDM stuff
Just purchased a fan switch from JDM to turn on the fans at operating temp, i installed two 14" fans that come on all the time now and didnt want that, so purchased this switch, it has one terminal up top and i am assuming sends a ground signal when the fans are to turn on so if i am correct this terminal goes to the ground side of a relay, if not please let me know where it goes.
also i purchased a boost bypass and did not get a diagram, so if someone has one to scan or good step by step instructions please post
thanks jim
thanks jim
Jim:
I saw a detailed, step-by-step set of instructions for the fan and wiring kit over on www.svtperformance.com a few days ago. I can't remember the exact site but you should be able to do a search. You might want to get in touch with JJsSVT there or at www.nloc.net. for the by-pass info.
Dan
Dan
