Lug Nuts for 2000 Lightning
Old Feb 3, 2002 | 10:00 PM
Masterloggie's Avatar
I have a set of aluminum wheels with drag radials. The wheels require a tappered lug nut. Is there a cross reference for using an existing Ford truck lug nut? Or what is the size I must order from a parts house. None of the tire shops here have any in stock and went to 5 parts shops and they said they had no idea with the course thread. Help please. I am sure they are 14mm, but what is the thread? Is there a suitable Ford replacement part?
Old Feb 3, 2002 | 10:06 PM
THEAUTOMAN's Avatar
If you are just wanting any old lugs the easiest way is to go to the parts store and get some standard nuts for a 2000 up work truck type truck with plain old steel wheels (like the spare) McGard makes some chrome ones, can't remember the part number but I think they are 14x1.5mm
Old Feb 3, 2002 | 10:12 PM
LightningTuner's Avatar
The size you need is 14mmX 2.0. There are no OEM Ford lugs in this size that are tapered seat. You will need an aftermarket lug. The ones I had gotten for my Bajas were made by Gorilla. Most places do not stock this size. Good luck .
Old Feb 5, 2002 | 11:46 AM
Sal,
Thanks..... I got some on special order. As you said Ford does not have the tapperd seat type in the 14mm x 2.0 .
Ron
