Engine rebuild questions
Old Jan 31, 2002 | 07:56 AM
ib fast's Avatar
Lightbulb Engine rebuild questions
Anyone know if resleeving is required to go .20 over? Also does anyone know if the compression ratio would change to 9 to 1 when going .20 over?
Old Jan 31, 2002 | 08:06 AM
lightning Jeff's Avatar
You should not have to resleeve if your only going 20 over.
All depends what pistons are out there. You might beable to find a lower compression piston then what you have now.
Old Jan 31, 2002 | 05:36 PM
ib fast's Avatar
Question
One of the tuners says you do have to resleeve for .20 over so i take it that know one knows? Also i was told by the guy i am buying the pistons from that .20 over would result in a 9 to 1 compression. Anyone know if this sounds right?
