Anyone have problems installing 3:73s?
Old Jan 24, 2002 | 02:00 PM
99BlkLitng's Avatar
I am getting the 3:73s put in my L as we speak but they (installers) said that there is something unusal about the housing. They said that the gears (ford parts) are for 99.5-02 Ls and mine (1999L) was made with an earlier rear end. They said that I have to get a kit that will make it so the gears will fit but I was wondering if there is anyone out there that has done the gear swap that has run into this problem.
Damon
Old Jan 24, 2002 | 04:00 PM
99BlkLitng's Avatar
ttt
Old Jan 24, 2002 | 04:02 PM
11secL's Avatar
I haven't heard of any problems with the 3.73's. I just had the 4.10's put in and that did take a few extra shims etc... but the 3.73's should not be a big problem.
Old Jan 24, 2002 | 04:10 PM
easterisland's Avatar
When I bought gears for my fathers 99 the place where I bought the gears said there were 2 different types of pinion bearings?? I really don't remeber but one was smaller than the other.
Old Jan 24, 2002 | 11:57 PM
99REDBOLT's Avatar
Thumbs up
there are two different types of pinion spacers or crush sleeves.
one is a collapsable crush sleeve and the other is just a solid pinion spacer that slides on the pinion instead of the crush sleeve. ford carries both and they both give you a different pinion depth depending on which housing you have. this is probably where your problem is at.
Old Jan 25, 2002 | 08:33 AM
lihtning's Avatar
My 3.73's should be arriving today! How long would it take an experienced mechanic/shop to do the complete install on these? Just wondering how many hours I should be expecting to pay for. Thanks
Old Jan 25, 2002 | 09:29 AM
casper lightning's Avatar
I had the same problem. I got mine done at ford. They gave me the right set up under warranty
