race gas ?
Old Jan 23, 2002 | 06:21 PM
mbrown's Avatar
race gas ?
I'm going to the track this weekend and I want to mix race gas w/ 93 octane. I want to make sure that I get no detonation. I know that if it doesn't detonate on the street then it shouldn't on the track, but the last two times I've gone, it has. I have a #4 pulley, 90mm mass air, open filter, power cooler, and chip. Any info is appreciated. Mike
Old Jan 23, 2002 | 06:23 PM
lariat4by4's Avatar
just add about 3 gallons to what you have in the tank when you get there.
Old Jan 23, 2002 | 07:15 PM
LIGHTNINROD's Avatar
It's too late now(for delivery) but some of us are using Torco Accelerator. It's a race gas concentrate that works and is mixed with 93 oct. and is less expensive than $4.25/gal. gas. 16 oz. withe 10 gals. of 93 will give you 97 oct. They have a site--www.torcoracinggas.com I think.
I'll let cablebandit and CornerCarver chime it with what they have found to work, You may not believe it?
Dan
Old Jan 23, 2002 | 07:18 PM
mbrown's Avatar
Thanks alot lightningrod thats alot of help. I do believe that its too late for this weekend but maybe I'll get some for next time.
Old Jan 23, 2002 | 07:23 PM
mbrown's Avatar
I found the site, www.torcoracingfuel.com but which fuel is it?
Old Jan 23, 2002 | 07:33 PM
CornerCarver's Avatar
1 gallon of Xylene (from Lowe's, Home Depot)
3 gallons of 93
1 oz. of Marvel's Mystery Oil (to prevent cylinder wall washdown)
The above will make 4 gallons of 100 octane unleaded race gas. It works, and yes I've used it. It cured my detonation until I got the chip reburned. Most race gases above 100 octane are leaded and with repeated use with eat O2 sensors.
You can also substitue 1 gallon of Toluene for the Xylene and Marvel's Mystery Oil mix and this will give you 4 gallons of 99 octane unleaded race gas.
Old Jan 24, 2002 | 08:27 AM
m:
It's the unleaded 'Accelerator'--thanks for correcting the web site addy.
Dan
Old Jan 24, 2002 | 08:50 AM
mbrown's Avatar
CornerCarver, there is a Bp up the road from me that sells 100oct. unleaded. Would you recommend a couple of gal. of that mixed w/ the 93 or the setup that you speak of. BTW, thanks for posting. I would've never known about that Xylene or the Toluene. Let me make sure I've got this right. If I mix 1 gal. of Xylene then I will also need 1 oz. of the Marvels, but if I use the Toluene then I wont need to mix in the Marvels? Also, which one is better to use? Thanks again
Old Jan 24, 2002 | 10:04 AM
lurker's Avatar
CC,
I've looked for Tolulene in the past and haven't been able to find it. There are chemical places you can order it from but they won't ship to a residential address.
Have you purchased Tolulene? How much is a gallon of Xylene?
Thanks.
Mark
Old Jan 24, 2002 | 10:13 AM
lightning's Avatar
CornerCarver
All we can get is 91 octane gas here, what mix ratio do you have to use to get 100? thanks Dennis
Old Jan 24, 2002 | 10:52 AM
mbrown, Check you email
You can get a gallon of Xylene from Lowe's for $9.50. Mix it 3 gallons of 93 @ $1.05 (here in GA) and you get 4 gallons of 100 for $3.16/gallon. $4+ at the pump here and they don't always work.
You can buy it in 5 gallons can for alot cheaper ~$6/gallon from paint supply stores (Sherwin Williams, etc.) You should also be able to find Toluene at a paint supply store. You should be able to make race gas for ~$2.25/gallon with a 5 gallon can. ALOT cheaper if you buy a 55 gallon drum. Right cablebandit?LOL
Xylene is 121 octane, Toluene is 117.
Just average the octanes to get a very close approximation of your tank octane. Don't foget the gas in your tank!
For example:
1 gallon of Xylene and 10 gallons of 93
[121 + (10x93)]/11 = 95.54 octane (11 gallons total)
Using Toluene (same amount)
[117 + (10x93)]/11 = 95.18 octane (11 gallons total)
Another example using 5 gallons of 91:
[121 + (5x91)]/6 = 96 octane )6 gallons total
NOTE:
Never mix Xylene stronger than 30% of total mixture
Hope this helps guys.
Old Jan 24, 2002 | 11:35 AM
mbrown's Avatar
Corner Carver, thanks again man. The Lowes in my area have quit selling Tolulene but you can get the Xylene in 1 gal @ $10. I'm trying to find someone to sell me 5 gal. of it. So far Ace Hardware and Lowes dont carry it. Now were hitting up some paint and body shops.
Old Jan 24, 2002 | 11:42 AM
mbrown's Avatar
Btw Corner Carver, I didnt get a email. Try this Mbrown428@msn.com thanks
