How do ya like your line mod valves?
I just ordered a line mod valve and stiffer 1-2 shift spring for my tranny from JL. Hoping it helps the slide I have into 2nd gear. How is yours holding up? Hows the shift? Just hope its not a real pain to install.
Ive read somewhere that some of you are barking the tires on the 1-2 shift! How does 3rd feel?
Skank,
Did you get the medium or hard shift? I just got the medium and I love it. I use to bark the tires with the F1's, even hit 3rd a few times. With the 20's it just kind of hits good. The tires differance took away the chirp sound....
I love it though!!
I love it though!!
Yeah do the deep pan and filter as well, You get a drain plug once you do that. I didnt know about it when I did mine So get to make a mess again!!
There may be a Lightning running at Laguna Seca in February with the PSP/Factory Tech performance valve body installed. And if I'm lucky and the owner is willing, I'll be able to drive it around the track to test whether or not the shifts hurt or help on a road course. Worst case is that I'll ride shotgun. Either way, I'll post a review.
One a side note and warranty issues, I hope Ford will honor the body warranty if the sheet metal fails to retain it's shape in case of a collision with a wall.
Spike
Red 2000 Lightning, #4033 (30 - __: not enough)
1967 CJ-5 (0 - 3 mph: yes)
White 1996 Whippet (600 yard course, 6 turns: 40 Seconds)
Red Wheaton 1995 Ridgeback (1/2 loaf of bread, 6 bites, 4 seconds)
2001 RR Puppy: 0 to destroy! - next 10 months
My video page
Spike
My video page
Originally posted by mbrown
What ****** said. I have the hard valve and I like it pretty good. Also, the work is a breeze but definately switch to the 4x4 pan and filter. I picked both up from Ford for less than $50.
It would be a good time for you to pick up a 4X4 trans pan and 4x4 filter at your local dealer parts dept.(cheaper than JDM's and same thing) when you put in the spring and valve.
DL
JL Enhanced
DL
JL Enhanced
