Need wiring help
Old Jan 20, 2002 | 07:02 PM
EvilGuy's Avatar
Need wiring help
After looking under my dash I can't even see where the hell the grommet is that goes to the door. Could someone please tell me how they did it and give some hints.
Old Jan 20, 2002 | 07:37 PM
usahooters's Avatar
I guess your looking for the wires to the speakers or the key pad. The hole is there, on the drivers side it harder to see because of the brake pedal. Look on the other side first to get an idea of where it is and all. If your running wires for an AMP or something I ran mine out the hole in the back corner of the cab and down the frame to the Batt. Hope this helps.
Old Jan 20, 2002 | 07:40 PM
abullerm's Avatar
usahooters:
What type of plumbing did you use for the wires running under the truck?
Old Jan 20, 2002 | 08:03 PM
EvilGuy's Avatar
I got the passenger side done but I just can not see the hole on the driver's side for the life of me.
Old Jan 20, 2002 | 08:05 PM
clonetek's Avatar
hey dude.. didja get my email?
i'll go look at my truck in a sec & tell you whats up..
i'm not at home, so i cant access my email right now.
brooks
Old Jan 20, 2002 | 08:08 PM
EvilGuy's Avatar
my email is on my other comp, i'll check it as soon as i get to it
Old Jan 20, 2002 | 08:25 PM
clonetek's Avatar
okay.. i looked at it. i remember now. that side is a #itch!
it's been a while, but i think i remember how i did it.
you take the rubber boot off that goes between the door & cab,
then using a flexible rod (or your fingers) feed the wire from the outside of the cab. you'll have to fish around behind the parking brake to get it out.
after you get that done, feed the wire thru the boot into the door, and the other end under the carpet to your amps..
oh, if you do check that email, you'll get a pic..
hope this helps.
brooks
Old Jan 20, 2002 | 08:28 PM
clonetek's Avatar
my cell # is (318)614-4289 if you need more help..
i'll check back on the board from time to time tonight.
brooks
Old Jan 20, 2002 | 10:21 PM
clonetek's Avatar
i'm guessing you either figured it out, and are enjoying the music... or you've got your hand stuck and are buzy cussing..
Old Jan 20, 2002 | 10:45 PM
'00BlackLightning's Avatar
When I installed the Kicker components on the doors, I ran new wires rather than use the factory wiring. I used a coat hanger with the end folded over to eliminate cutting the existing wiring and snaked it through the grommet, rubber tubing from the door side. I ran the coat hanger well into the cab side so that it hung down from below the clutter. Tie the new wiring to the end of the coat hange still inside the door and tape it to allow easy access through the grommet. Pull the coat hanger all the way out from the cab side along with the new wire. Just be careful not to nick the factory wiring when snaking the new wire through. It took about 1 hour to complete.
Old Jan 21, 2002 | 02:01 AM
EvilGuy's Avatar
brooks, lol I said f00k it and packed up for the night and hit the town with friends. I'll get it done as soona s i wake up and get pictures of my bleeding hands for ya
Old Jan 21, 2002 | 02:11 AM
clonetek's Avatar
LOL!
i drove around without my passenger seat for a few days for the same reason... too much stuff to install, not enough time.
good luck!!
