01/02 Pulley
Old Jan 19, 2002 | 06:04 PM
11secL's Avatar
01/02 Pulley
I am sure this has been duscussed before but I cant find it in a search. Will an 01/02 pulley work on a 99/00 L?
Old Jan 19, 2002 | 06:15 PM
JeffsLightning's Avatar
yes
Old Jan 19, 2002 | 06:21 PM
LightningTuner's Avatar
If you are talking about the PSP designed cageless pulley, then an 01/02 style will not fit a 99-00, unless it has an 01/02 balancer on it. I'm not 100% sure, but I think the JDM style pulley will work on either.
Old Jan 19, 2002 | 06:23 PM
4D THNDR's Avatar
Lightbulb
If you are refering to the lower crank pulley someone said the 99/00's have different bolt patterns than the 01/02's. Probably should ask the vendors.
Old Jan 19, 2002 | 06:25 PM
11secL's Avatar
There is a 6# JL Pulley in the classifieds for a 01/02. I was wanting to upgrade from the 5# but I am not sure if it will fit my 99.
Old Jan 19, 2002 | 08:32 PM
usahooters's Avatar
You can get a new one from JL for 255.00
Old Jan 19, 2002 | 09:00 PM
ICULOKN's Avatar
as Sal said, a 01 or 02 will not fit a 99 or 00 unless the truck has a balancer from a 01 or 02 motor. If you have a 99 or 00 with a 01 motor it will work, otherwise I doubt anyone has just changed a balancer...
Old Jan 20, 2002 | 10:23 AM
walker887's Avatar
Won't work
Old Jan 20, 2002 | 10:38 AM
LIGHTNINROD's Avatar
I think you guys misunderstood(easy to do because he didn't supply enough info) the question.
11secL has a 5lb on now--the 6 lb should fit fine--may have to adjust the trans coolant lines down a tad? Hop I 'understood' him correcectly ?
Dan
Old Jan 20, 2002 | 10:47 AM
ICULOKN's Avatar
He has a 99 or 00, yes he has a 5lb but he saw the classified ad for a 6lb for a 01 or 02 for sale. WILL NOT WORK!!
Old Jan 20, 2002 | 10:49 AM
walker887's Avatar
He asked if a 01-02 pulley would work on a 99-00 , no misunderstanding that....definate NO
