Long-tube headers + 4lb pulley (before & after rwhp)
I had the long-tube headers and the 4 lb lower pulley installed today. Before and after # for long-tube headers + 4lb pulley (Nitrous was not used) are as follows:
Before: 383 rwhp - 461 torque (2 lb lower pulley, bassani headers)
After: 415 rwhp - 508 torque (4 lb lower pulley, long-tube headers)
Therefore, these two mods were good for 32 rwhp and 47 torque. I wish I had dynoed the truck after each mod so that I could have determined the gain from each.
I also need to get my chip re-burned since the air - fuel ratio was 10.0. The guys at the shop said that I should be able to get at least another 10-15 rwhp by changing the air - fuel ratio to @ 12.0. Not sure if they are correct, however, I am happy with the results.
I had the work done by APEX Motorsports in San Jose. These guys are awesome!!!!! I highly recommend them..........
Sal-
Thanks, will do. By the way, I just realized that I did not tell them to take the oil breather cap off of my truck...... Could that have affected anything??
Thanks,
Dave
Thanks,
Dave
Re: wow
Originally posted by DaveRed99
so i can hit up sal for some stuff!
Dave C, you can leave that on, I'll take that into account..
Dave,
Thanks for posting your dyno numbers on your new longtubes and 4# pulley the numbers look great! I dynoed the 2# compared to the 4# and there was 8HP and 24 pounds of torque difference between the two pullies.So I would say you picked up at least 24HP and 23 pounds of torque with just the longtubes alone!When you get your air-fuel back up around 12.0 you could see possibly another 10HP!
Whose longtubes did you go with?
Matt
Whose longtubes did you go with?Matt
Matt-
Thanks for the info... The headers definitely seem to be a worthwhile investment.
I picked mine up from JDM. With Sal's street program, it is hard to keep the wheels from spinning. I was amazed at the difference that these two mods made.
Dave
I picked mine up from JDM. With Sal's street program, it is hard to keep the wheels from spinning. I was amazed at the difference that these two mods made. Dave
Prior to the long-tube headers, I had the full Bassani setup - headers, cats, and cat-back. The long-tube headers come with cats, and the shop used my existing Bassani cat back, however, they said that some cutting was involved to get the cats aligned with the cat-back. With the stock exhaust, I believe that you would just use your existing cat back. In other words, you would replace the headers and the cats and keep your existing cat-back. By the way, this was one of the best mods that I made. DO NOT waste your time with Bassani headers!!!!
Mondo-
You are correct - sorry for the confusion. Actually, there were several additional costs on top of the headers;
Gaskets: $26.00
Cats: $300.00
Collector Gaskets: $20.00
Flanges: $50.00
O2 Harness: $30.00
Gaskets: $26.00
Cats: $300.00
Flanges: $50.00
O2 Harness: $30.00
I was told by several people including my ford mechanic that the stock steel head gasket will not have to be replaced when putting on headers,did you just want to be certain or was there damage to your stock one!
Matt
Matt
