UPDATE to Rough Idle Saga...
Old Jan 18, 2002 | 07:55 AM
01Lightning's Avatar
Hey Don,
Were you having the vibration problems with your Magnaflow, or did you just have the weights installed when the Magnaflow was installed just to make sure?
I have a Magnaflow 14468 and have not had any vibration issues at all.
Old Jan 18, 2002 | 08:10 AM
Don's Bolt's Avatar
Originally posted by 01Lightning
Hey Don,
No I was having the problems with the stock system, the weights helped the vibration but didn't totally get rid of the problem. When I put the Magnaflow and since I had the weights, I decided to put them on the new muffler.
With the Magnaflow and the weights the truck is nice and smooth.
Old Jan 18, 2002 | 08:21 AM
BMWBig6's Avatar
2_FAST4U, I am going to Ted Britt Ford.
WHAT04, all of the pieces are coming together now. I remember now that they replaced my muffler right when I bought the L because it made a weird "squealing" noise (like belts) when the engine was hot. When delivered new from the factory, I noticed that my exhaust looked a little lower than everyone else's and didn't even fill the cut-out in the side-skirt. It didn't look great, but in hindsight it didn't vibrate either (just squealed). When they replaced the exhaust muffler, I picked it up and the first thing I noticed was that it was mounted a little higher in the cut-out, which pleased me. But now I am realizing that it may have been mounted too high, and over time has been "rubbing" against the floorpan or body as you describe. I wonder if remounting the whole thing a little lower again will solve my problem without using the dampeners at all...
