I want to lower the back of my L 4" what is best way?
Old Jan 17, 2002 | 10:58 AM
TAKECOVER's Avatar
I already purchased Belltech 2" coils for the front, and now I am ready to drop the rear. I already have 2" shackles, so the logical thing to do would be hangers. Does anyone have an input on installing the front hangers? I really want to keep the excellent ride of the truck, but I am open to suggestions!
Thanks,
Jimmy
Old Jan 17, 2002 | 11:08 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
4" will sit lower than the front if you only did Belltech springs. 3" is level.
4" will bottom out on rough roads. 3" is a much better ride.
Hangers are a bit*h to do.
I'd look for an alternative for that extra inch. Remember to install pinion shims if you go that low.
This is a true 3" front, 4" rear(28.5" to the ground in all four corners).
Old Jan 17, 2002 | 11:12 AM
captainoblivious's Avatar
Rich - nice ahhhh, shirt yea, nice shirt
TAKECOVER - what you do is take off the rear springs and leave the stock shocks on. That should give you the height you want. Seriously though, consider what Rich said, a 3" would better.
Old Jan 17, 2002 | 11:24 AM
TAKECOVER's Avatar
Good point, I forgot about the truck already dropped 1" in the back! I would need to do a 3" drop in the rear to keep the truck level then. Thanks guys, I do not want to be lower in the rear for sure!!
