Pulley swap
Old Jan 15, 2002 | 11:24 PM
LatemodelRacer2's Avatar
Pulley swap
On the 2001 lightning, is the top pulley larger than the bottom? If so could you not just swap the two pulleys and gain boost and in the end not have to buy a new belt? If anybody knows if this is possible please post u ur comments.
Old Jan 15, 2002 | 11:37 PM
Masterloggie's Avatar
Top pulley on the SC is smaller. The lower pulley is larger.
Old Jan 16, 2002 | 08:00 AM
LIGHTNINROD's Avatar
You would not have any boost even if it were possible--if you want more boost, then either increase the lower and/or decrease the upper diameters. Come on man--the belts are only $35 or so.
Dan
Old Jan 16, 2002 | 08:26 AM
Don's Bolt's Avatar
I have a 2# lower pulley, and a 1.5# upper pulley and am still running the stock belt.
Old Jan 16, 2002 | 09:16 AM
Silver-Bolt's Avatar
The pulleys are not interchangable. I currently run a 4LB lower and still have the stock belt.
