Need help on shackle install!!!!!
Old Jan 14, 2002 | 10:19 PM
J15BIG's Avatar
I just got my ground force 1/2 drop today and am in the process of installing the first shackele. I got the top bolt in but i am having trouble with the second. I can get the bolt to go in hald way, but when i try to make it go all the way through, the wholes dont line up. I cant get the freaking things to line up. I have tried everything. Any suggestions. I have tried putting something smaller through and circling it around to see if it will line up but no. someone please help. This is rediculious. Its been like 2 hours since i started and havent even finished the first shackle!!!
i am about ready to remove my hitch just so i can get to the other side of the damn shackle
Old Jan 14, 2002 | 10:27 PM
Probleminfected's Avatar
put a long peice of something (metal, wood) between the bed and the top of the shackle and pull down.
it should line up, it took me 4 hours to do my shackles because i'm a half retard hahaha
Its all about the leverage baby
Old Jan 14, 2002 | 10:33 PM
harleyrules's Avatar
Use your floor jack, place it under the rear and jack it up or down depending on which way you need the spring to move. I did the shackle install and it only took 30 minutes to do both sides. Good luck...
