Service Engine Soon Light
Old Jan 13, 2002 | 09:26 PM
J MAN's Avatar
Exclamation Service Engine Soon Light
Just had a new enguine put in my truck,it's an 00,with an 01 engine.Anyway mecvhanic said he got a SES light ran diagnostics and said the lefy bank was running lean.We reset the light, it came on about 14 miles later,reset,came on 15 miles later,reset,came on 25 miles later.Ok ideas????. There is no chip in the truck,the engine in brand new.Is it a sensor,or fuel filter,or???? >Kinda of puzzling but seems as though the truck is running great but lean isn't good.I'm taking it in for another scan tomorrow,thougt I'd see what you all think since more times tahn not your right on the money where the mecehnics seem a bit puzzled at times.
Thanks for the Help!
Jerry
Old Jan 13, 2002 | 09:50 PM
2_FAST4U's Avatar
Jerry,
I am leaning towards the PCM. Did you upgrade it???
I am not 100% sure if a upgrade is nessesary, but you might want to ask!!
Old Jan 13, 2002 | 11:24 PM
Blown93's Avatar
I also say PCm....
New Blue 2002
no mods
Blown 93 Lightning
Many mods
13:20
102.00
Old Jan 13, 2002 | 11:29 PM
FlashSVT's Avatar
http://www.svtperformance.com/forums...&threadid=9694
Old Jan 14, 2002 | 08:34 AM
LIGHTNINROD's Avatar
J Man:
I'll bet your 00 PCM still thinks you have the 00 80mm MAF--but then again, you may(thinking about this as I key...) if all that was changed was the eng. That's all that I can think of..............
Dan
Old Jan 14, 2002 | 10:57 AM
J MAN's Avatar
I previously had a 00 engine with a 90mm mass air,and had a chip done to accomodate that.I tried the new engine with the same chip,but got the same results.In my way of thinking shouldn't the chip accomodate for the 90mm,and if the pcm is looking for an 80mm and the chip is burned for a 90mm,shouldn't that solve the problem?
J MAN
Old Jan 14, 2002 | 11:01 AM
Don's Bolt's Avatar
Maybee the dealer reflashed the computer?
Old Jan 14, 2002 | 11:08 AM
2_FAST4U's Avatar
Jerry,
I know what your saying, but if the '00 PCM has a default for a 80mm then that is what it will look for. There are lots of variables that I am not aware of at the moment, but there maybe something that your old PCM is looking for and cannot find.
I am not good with automotive computers, but I do have a degree in computer electronics and I know that if you swap or change anything in a regular computer or on the machines that I work on, you will have HUGE problems with the machines recognizing their purpose and their components.
I would try to get '01 PCM for '01 engine.
Just mt .02
Old Jan 14, 2002 | 03:34 PM
reality1's Avatar
Jerry,
Give me a call if you have time.
Old Jan 14, 2002 | 05:10 PM
J MAN's Avatar
Don
Not a reflash on the computer,it should work,but then when you get a code lean left bamk could also be a leak around the collector,or maybe a header gasket,well time will tell.The motor is very strong I had the manley rods put in it and am very confident it will last the entire season and more...
Jerry
Old Jan 14, 2002 | 05:13 PM
J MAN's Avatar
2 fast 4 u
We should have the BB up and working by weeks end,thanks for yopur imput.
