Dash Cluster Lights are OUT!!!!
Old Jan 13, 2002 | 01:11 AM
Lightning#838's Avatar
The fuel, speedo, tach, boost, etc. lights are out! What do I do, it's not the dimmer switch. EVERYTHING else works. Checked the fuses that would pertain to the lights but no. What do I do, I don't want to take it to the dealer. Please HELP
Old Jan 13, 2002 | 01:12 AM
97GreenLariat's Avatar
make shure you've checked all fuses, including ones under the hood.
Old Jan 13, 2002 | 11:45 AM
SVT_01_Sparky's Avatar
Had the same problem with my 2001, dealer had to replace entire gauge cluster. There isn't lamps to replace.
good luck
ttt
Old Jan 13, 2002 | 04:25 PM
Frank S's Avatar
I hate it for you but you're going to have to go to the dealer to replace the gauge cluster as said above if all the fuses are good. Look on the bright side, at least it failed under warranty.
