Cam Bolt & Alignment Specs
I went to the local parts store and got (2) cam bolt kits TRW # 132778A "Ford Light Truck Alignment Cam for 1997 & newer F-150. Couldn't find a NAPA store. The truck goes in for alignment as soon as I install the parts this weekend. Now for the questions:
Is this the correct kit for a TRW part?
Are the stock alignment specs still good for my 1/2 dropped L?
Or do I need some other specs?
I have seen others take in their own specs after lowering.
Do I need two cam kits to do the alignment?
Do I need an alignment after only dropping the truck 1 inch in the front? She handles well and drives straight. Not enough miles to see uneven wear though.
Lastly, I wish I would have bought and installed theses kits when I had the front end apart.
Thanks for the replies. R/S Dennis
Make sure you take it to a good alignment place. I didn't go to a great one and am not that happy with it, so my truck will be going in for another aligment as soon as I change stocks.
Hope this helps:
https://www.f150online.com/forums/sh...lignment+specs
Hope this helps:
