Lightning Cam Lift?
Old Jan 4, 2002 | 08:15 PM
Flats Man's Avatar
Cool Lightning Cam Lift?
What is the stock cam lobe lift on the Lightning? I show a stock 5.4L is: Exhaust Left = 0.260
Right =0.259
Intake =0.2593
Thanks for you input!
Old Jan 4, 2002 | 09:41 PM
Flats Man's Avatar
Cool
O K where are you Tech types?
SHM Blower Cams .452 Lift Intake
.452 Lift Exhaust
What is the Stock Lightning Lift?
Old Jan 4, 2002 | 10:12 PM
modularman's Avatar
valve lift specs are 13.01mm intake 13.75mm exhaust
sorry forgot how to convert to inches specs are from 2001
ford service manual
Old Jan 4, 2002 | 10:16 PM
modularman's Avatar
i think the conversion is 13.01 divided by 25.4 =.512
and 13.75 mm =.541 ????????????
Flats Man's Avatar
Cool
Thanks Mod Man, I will convert it tomorrow morning. Thanks for your time!
Old Jan 4, 2002 | 10:18 PM
Flats Man's Avatar
Cool
Wow! If your conversion is correct, that is quit a bit of difference from a stock 5.4! I just went to a conversion calculator and you are exactly right. Thanks again!
Old Jan 4, 2002 | 10:28 PM
modularman's Avatar
just went back into service manual and cams specs are
same for both lightning and improved power 5.4 1999 and
up ?
Old Jan 4, 2002 | 10:36 PM
Flats Man's Avatar
Cool
That is VERY interesting.
Great info!
Old Jan 5, 2002 | 01:42 PM
Neal's Avatar
Cool
HI!... I was at my dealers the other day and asked about cam lift on the 5.4. I was told 0.512 intake and 0.541 exhaust. They also showed me on the computer that the reg 5.4's and the LIGHTNING 5.4's use the exact same camshaft profile. This is for the "99" and up reg 5.4's. The pre "PI" 5.4's have a smaller grind.
