Blew Motor
Old Jan 4, 2002 | 08:01 PM
fast forward's Avatar
Blew Motor
wanted to tell everyone blew the lightning up
number 3 and 5 push rod threw the block man what
a bummer oh well now its time for a real motor .
hey guys i think its time for al of you to beef up those rods..
bringing it down to jdm will take pictures of the new intercooled
block lol later
Old Jan 4, 2002 | 08:12 PM
tallimeca's Avatar
exactly why i'm stock
untill the warrenty is up at least. Don (Don's Bolt) has his truck down to JDM for an upbuild (his didn't blow up first). Can't wait to see the power increases.
Old Jan 4, 2002 | 08:22 PM
ICULOKN's Avatar
Fast,
What mods did you have?
Old Jan 4, 2002 | 08:23 PM
retics4me's Avatar
What mods did you all have and what times were you running? i know ill blow my engine one day but hope i can get one more season out of it ..
Old Jan 4, 2002 | 08:39 PM
Don's Bolt's Avatar
Re: Blew Motor
Originally posted by fast forward
wanted to tell everyone blew the lightning up,
block lol later
I am glad you can laugh about it, I know if I blew mine up I wouldn't be this upbeat.
When you go down to Jim's say hi to my truck. I have a feeling she is lonely.
I hope every thing works out OK for you
Don
Old Jan 4, 2002 | 08:41 PM
single blade throttle bodie,air filter ,electric fan &cobra r water pump, boost bypass,upper pully 2lb, 6 lb lower, chip, headers,
exhaust , and other goddies ran an 12.1 on f1'2
Old Jan 4, 2002 | 08:47 PM
Fast Gator's Avatar
Does that mean with the 2lb upper and the 6lb lower that =28? My thoughts, 6+8=14, 14X2=28 Is this correct math?????????
Old Jan 4, 2002 | 08:54 PM
soap's Avatar
What??????
Why multiply by 2?????
2+6+8=16#........thats what I think.
--Joe
Old Jan 4, 2002 | 09:05 PM
lightning Jeff's Avatar
12.1 on F1's Wow, that is fast.
I was sick when my motor blew.
I lost the number 3 rod then it broke the number5 and number 7 rod. Hole in the pan and a big hole in the block.
Went to a different combo. I am very happy with what I am running and who I have doing the tuning this time. I am running a 4# lower and and stock upper on the new motor. I am to scared to do the 6#lower and 2#upper pulley.
Old Jan 4, 2002 | 09:10 PM
Master Of Pain's Avatar
Eight pounds of boost plus boost bypass = bad idea. Too much boost and not enough release will *** up a motor quick.
Old Jan 4, 2002 | 09:12 PM
HIGH ROLLER's Avatar
Cool
fast forward,
Sorry to here this,can you tell me what rpm your chip was shifting at and have you had any problems running to lean with you chip?
Matt
Old Jan 4, 2002 | 09:15 PM
LIGHTNINROD's Avatar
gator:
What soap said. And maybe 1 or 2 more from the open air filter?, but not 28.
Dan
Old Jan 4, 2002 | 09:20 PM
Cool
Something else to consider is most new stock trucks are 8-9 pounds of true boost from factory then comes the airkit and throttle body another 1# plus chip and 8#'s from pullies then the cold air is good for another 1# along with lean conditions from the cold dry air so he could of been pushing upwards of 18-19#'s of boost when it blew! Cold weather is very hard on our trucks unless you have a chip that is programmed for it!
Matt
Old Jan 4, 2002 | 09:31 PM
Fast Gator's Avatar
OK Thanks for the answers, I just thought, (Thought wrong) that the upper pulley multipled the lower, but instead just adds the lbs of boost to the lower number. Thanks
Old Jan 4, 2002 | 09:35 PM
ICULOKN's Avatar
This is why the 6lb lower will be my limit. I think with the 6lb & a open filter I am be close to 15 or 15.5 tops. It seems to me once you pass 17 you get on deadly or timebomb style stuff. If you have a good chip, you let off when you get in a spinning cituation, & listen for pinging, you shouldnt have a problem. Thats my thoughts. Of course there will be mechanical failures from time to time. If you stay away from the top pulley you can really put the truck back to the stock look to. I ran 15lbs on my 91 GT with slight mods and never had a problem. Any Comments?
