Auburn Posi?
Old Jan 4, 2002 | 03:45 PM
11secL's Avatar
Auburn Posi?
I am rebuilding my rear end with the Auburn Posi unit. I know they are a heck of alot stronger than the stock but they claim quicker response and much better traction. Has anyone tried this unit yet? Any feed back for it. I am having it installed with 4.10 gears so I may not be able to tell how much I benefit if it do at all. What is you guy's feed back on this unit?
Old Jan 4, 2002 | 04:06 PM
builtfordfast's Avatar
It's an excellent unit. Although I do not have this posi unit in the L , I did install the Auburn in my previous vehicle, a 1995 Formula.
It made a huge difference and I was very pleased with it. had the 4:10 gears. Pretty much indestructable.
I say go for it.
Old Jan 4, 2002 | 04:16 PM
ASVTFordBoy's Avatar
I have heard many good things about the Auburn...
That's why I used it in my Cobra. The only problem with the Auburn for regular track use is that it is a wedge cone design that it metal to metal. If, when doing a burnout, one wheel decides to get grab before the other one it will burn up the Auburn in no time. Once this happens, you can't rebuild it. That's what happened to mine.
I ended up going with a FRPP with a clutch pack and it worked fine. I figured if I burned up the clutches, at least I could rebuild it.
Old Jan 4, 2002 | 04:31 PM
11secL's Avatar
So it does work good for traction?
Old Jan 4, 2002 | 04:36 PM
I never had any trouble with traction until it burned up and wasn't posi anymore. Maybe mine was an isolated incident, but I had a few differential guys warn me about the Auburn before I bought it because it couldn't be rebuilt.
Old Jan 4, 2002 | 04:39 PM
blownlightning's Avatar
Good unit while it works.How ever it is non-rebuildable.I smoked one in my Fox Body and threw it away.
Old Jan 4, 2002 | 04:50 PM
jezze269's Avatar
I put in an eaton diff in my mustang a few months ago and I love it. I was going to go with the auburn but I found out about it being non rebuildable. The eaton has carbon fiber clutch packs. I belive it was cheaper than the auburn.
Old Jan 4, 2002 | 04:51 PM
ICULOKN's Avatar
What made the Auburn burn up? Low fluid? wrong fluid?
Old Jan 4, 2002 | 06:12 PM
Don's Bolt's Avatar
Jezze
What can you tell me about the Eaton diff?
I am thinking of upgrading my differential this spring, I am looking to find the strongest unit out there.
Old Jan 4, 2002 | 07:14 PM
jezze269's Avatar
Originally posted by Don's Bolt
Jezze
To me it seems a bit like a trac loc but it seems to plant the torque better, and I really like the the carbon fiber clutch packs. With my old trac loc I was smoking the clutches with my spirited driving. These carbon fiber ones arent showing any signs of giving up yet. heres a link to the eaton diff http://www.traction.eaton.com/prod3.htm
The odd thing is I read somewhere that lightnings came stock with eaton diffs. Ill do some looking to see if its true.
Old Jan 4, 2002 | 07:30 PM
ib fast's Avatar
Smile
jezze269, the lightnings do not come with the eaton but i was pitched the idea by a tuner to try the eaton when available[this was last year] I was wondering if you had any idea on the cost.
Old Jan 4, 2002 | 08:06 PM
Silver-Bolt's Avatar
I don't think the Auburn for the L is a wedge cone type. I could be wrong but I think it is a friction plate variation. P/N AUB542090
http://www.drivetrainwarehouse.com
Old Jan 4, 2002 | 08:10 PM
jezze269's Avatar
Ill try to find some prices. I got mine along with superior axles,and bearing from drivetrain direct to my door for $560.00. It was a pretty good deal I think.
Old Jan 5, 2002 | 10:20 PM
Nope, Good assumption though!Raw horse power.18psi & 75 wet shot of juice.
Old Jul 1, 2002 | 03:35 PM
How about an update? How is the Auburn working out? Feedback on going to 4.10's?
