25 Minute Belltech Shackle install
Ok not alot to it but I did these in 25 minutes.
Not alot of drop but did level it out better.
Not bad for 50.00 , but now I want more.
First get jack stands and tools. I went up 2 notches on my smaller stands. Placed under frame at front of spring
Then I loosened the nuts and removed them.
Lowered the rear end to the ground ...at 2 notched on the stands, my tire were on the ground
I then removed bottom bolt.
then I jacked rear end back up to removed top bolt.
Remove old shackle
Remove old shackle
Originally posted by ICULOKN
One thing I also did with that 2in shackles was put a 4deg wedge in to change the pinion angle. It really made the truck hook up good!!!
Dan
