Accident: need some help
Old Dec 30, 2001 | 02:34 PM
andrewjhaley's Avatar
Old Dec 30, 2001 | 02:37 PM
ICULOKN's Avatar
Damn dude, sorry to hear about that. The rims are like $250 each, might be able to find them alittle cheaper. Tires are around $200 each. Im not to sure how much a axle is but It cant be that bad!!!
Good luck!!
Old Dec 30, 2001 | 03:24 PM
Lightning Boy's Avatar
Unfortunatly I dont think you can use just any 9.75" rear end either. The shock mounts on the axle is stagard and unqiue to the Lightning (or so I read at one time). But then I would could be wrong. Try going to a junk yard and find some 5.4L F150's and/or Expeditions with the 9.75" rear end and pick one up for cheap.
Old Dec 30, 2001 | 03:39 PM
ib fast's Avatar
Wink
Sorry to hear of your problem andrew. Actually even though there staggered,the shock mounts can be grinded out and re-welded to position them correctly. Just make sure you change your fluid afterwards as welding can burn it. I reversed my stock set up to the standard position and back to staggered already in the name of traction so any one thinking of doing this...leave it staggered.
Old Dec 30, 2001 | 05:09 PM
MadMaxSC's Avatar
Good luck!!
The rims are not 250 each. Go to www.buyfordmotorsport.com
they are 189.00 each...you will not beat this deal.
Old Dec 30, 2001 | 05:22 PM
ICULOKN's Avatar
As I first said, you may be able to find them cheaper....
I always like to look at it in the worst way and anything better than that makes it cheaper....
Old Dec 30, 2001 | 05:31 PM
99 SVT Bolt's Avatar
www.tirerack.com
www.fordpartsonline.com
Old Dec 30, 2001 | 05:46 PM
thanks alot, i know insurance is going to cover it all, im just trying to figure out how much everything is
Old Dec 30, 2001 | 06:43 PM
DaveRed99's Avatar
Thumbs down outch!!
damb ......! Are you ever guna let your dad drive you truck !.>? i wouldnt let him !!!! but thats just me
Old Dec 30, 2001 | 08:04 PM
usahooters's Avatar
Unhappy
Sorry to hear about that Andrew, gotta teach dad how to drive better then that.
Old Dec 30, 2001 | 11:59 PM
Lit's Avatar
Lit
Andrew...sorry to hear about your loss. I know someone who did the exact same thing...snapping the wheel off of the rear axle. These trucks do not like curbs...as a lot of us had learned. The rear axle...just for the part is $1200...not to mention replacing caliper, brake pads, rotor, ect. Good thing you have insurance huh? Hope it all works out for ya.
Old Dec 31, 2001 | 07:45 AM
MYREDTOY's Avatar
Andrew that's a real bummer. Glad nobody got hurt. Give me a call if I can help you get it back on the road.
Steve
