Light weight aluminum rims
Thanks, i just got a number to order some 16i n 28 tall drag slicks so i can dump the et streets and heavy steel rims. After i order mine[no answer yet] Then i will give whoever wants them the #.Or is this already common knowledge?
ICKULON, i got this # from a trusted L source but so far no answer. Everybody and there L brother will want these slicks unless they already have the 15 in set up,so until i can order mine i am not giving any info...still no answer at the # i have for the seller.
HI!... MICKEY THOMPSON is supposed to be releasing a 16x11.50 ET STREET later this SUMMER. As for the BAJA RIMS, they are light but the back spacing is not what I like. It makes the rims stick WAY out side the truck 1/4 panels. I'm talking about the BAJA 16x10 not 16x8.
These are not m/t's, i will tell you that much, but they are 28in slicks that fit on 16in rims.I have had the 16 in m/ts for over two years but want a true slick that is 28 in tall. I may not be able to get ahold of the source till monday.
Neal, i want mine before nex,t summer...i need to have them on by early march in order to run some 11's. m/t has taken to long so i will go with this other wrinkle wall. Not sure if my new set up will do 11,s in mid summer,thats assuming m/t actually puts them out by then
