overdrive poll
Old Dec 27, 2001 | 05:47 PM
tallimeca's Avatar
overdrive poll
I know most everyone would agree on no overdrive for drag runs, but how do most of you run on daily driver, od on or off. I drove around last night for the first time without it on and it was like a different truck. I little more fun
Old Dec 27, 2001 | 06:05 PM
LTNBOLT's Avatar
Cool
There is NO advantage to turning O/D off at the track unless you are running out of gear at the end of the track. I have tried it two different times at the track. I made several runs both ways and there just wasn't a nickels worth of difference. If I had to say one was faster it would be with the O/D on but that would almost be stretching it.
Around town I could see it being more responsive with O/D off.
Old Dec 27, 2001 | 06:19 PM
Neal's Avatar
Cool
HI!... Running with the OVERDRIVE on/off has no effect on 1/4 miles times unless you need overdrive to finishe the 1/4 mile. All the overdrive switch does it TURN THE OVERDRIVE OFF OR ON that's it!!!!!!!
Back to the poll : I do ALL my ciy driving with my overdrive "OFF".
Old Dec 27, 2001 | 06:56 PM
NXsilversvt's Avatar
First of all, I doubt you'd want to let the tranny shift into overdrive under WOT (especially if you have a lot of mods). Second of all, overdrive off does a little more than just keep the tranny from shifting into overdrive. Try this... Take your truck out and get up around 35 MPH. Let your foot off of the gas (with the overdrive on) and feel what happens. It feels almost as if the truck is in neutral because it just more or less coasts, right? Now, try the same thing with the overdrive off. Feel the difference? The truck uses more engine braking and the truck slows down instead of just coasting. Just my 2 cents. By the way, does anyone know why the truck does this?
Old Dec 27, 2001 | 07:09 PM
MiamiWhiteSVT-L's Avatar
So how much of a gas (MPG) difference would you see if say, one tank you were to drive around with OD on all the time, and the next tankfull with OD off, assuming same driving styles both tankfuls.
BTW, I have yet to drive the truck with OD off........Don't know how it feels.
JC
Old Dec 27, 2001 | 07:15 PM
The Orphaner's Avatar
Registered User
Overdrive
I always thought you were suppose to turn off O/D when you were towing or city driving below 50 mph. To avoid the transmission "hunting" for the right gear. my .02
Old Dec 27, 2001 | 07:55 PM
'00WhiteLightneeen's Avatar
I think that if you let off at 35mph (and don't have a chip installed) the truck will shift into OD right after you let off. The engine isnt under any load at this point, so the computer tells it to upshift.
Old Dec 27, 2001 | 08:01 PM
1BADTK's Avatar
and there is no braking when the OD is off, that's just a natural drag down because of the 1:1 gearing of the differental as apposed to the .7:1 in OD. HELLO?
Old Dec 27, 2001 | 08:52 PM
ib fast's Avatar
Off in town under 50...and off on the 1320.
Old Dec 27, 2001 | 09:02 PM
alphadoggy's Avatar
Angry
Another reason that I dislike automatics; the tranny thinks it's smarter than I am (bite your tongue). Generally drive with O.D. off; the truck is more responsive that way, but its hell on the gas milage. But with my 4.10s I only get 9 mpg anyway, so do I give a rodent's behind?
Old Dec 27, 2001 | 09:47 PM
Factory_Tech's Avatar
If I was King of the world, the O/D off switch would be mounted in the bed and labelled "Towing In Mountains during Very hot Weather Mode". MOst useless and misused control in your cab. The computer DOES know better than you, even when it's hunting for the gear, just so happens that what's best for the box is sometimes kind of annoying, so if you want you can turn it off. Yes, it does engine brake, but again, so what? Just causes more wear when it does that....
Just what I think,
G
Old Dec 27, 2001 | 10:06 PM
J15BIG's Avatar
so F/T, you pretty much leave O/D on all the time?
Old Dec 27, 2001 | 10:17 PM
I turned it off once to see if the light worked....
Old Dec 27, 2001 | 10:34 PM
94LightningGal's Avatar
We leave O/D on all the time, city or highway. Like FT says, the tranny is smarter than any of us. Why get lower fuel economy? Goodness knows the thing surely shifts down plenty fast if you need it.
Oh, just for info sake....... the transmission will use some different internal components when you have O/D on or off. Well at least the A4LD's do (the only one I have worked on personally).
Plus, the exhaust sounds real good when it is lugging around at a low RPM in O/D and you are giving it a little bit of gas.
Old Dec 28, 2001 | 12:24 AM
In a 4R100 it's the same either way, it just disables the OD clutch and enables the coast clutch (ergo, the engine breaking)
G
