dash lights
Old Dec 27, 2001 | 02:05 AM
TheSilverBullet's Avatar
dash lights
Is there a way to change the indiglo dash lights from green to blue?
-DAN
Old Dec 27, 2001 | 02:17 AM
NOSTROMO
Guest
Posts: n/a
I believe it is a Flourescent lamp inside the cluster and is unservicable according to the shop manual. It also states that removing the cluster from the harness will require Ford to reset it. I guess it is a tampering feature built in.
Advice:
Leave it be...unless one of the tuners wanna step up to the plate here and give some info.
Anthony
Old Dec 27, 2001 | 02:53 AM
ICULOKN's Avatar
I think Nostromo is right,
They build stuff these days to be able to change out a COMPONENT not just a bulb or gauge!!! I think its stupid but alot of cars are getting like that!!!
Old Dec 27, 2001 | 11:47 AM
Rumba83's Avatar
Talking
I know that if you have the cluster replaced, you have to reprogram the pats key system, cause its run through the cluster. The lighting system is non-servicable, except as an assembly, i've had mine replaced once already.
Old Dec 27, 2001 | 12:09 PM
Spiro99SVT's Avatar
Advice:
Anthony
For what its worth..I have had the cluster out, and disconnected from the main harness...never had any problems re-installing it.
Old Dec 27, 2001 | 12:16 PM
soap's Avatar
Spiro.........what haven't you done to your truck
---Joe
Old Dec 27, 2001 | 12:20 PM
Spiro99SVT's Avatar
Joe,
LOL..never did a convertor, or other fancy GO-GO Mods that some require top achieve sub 12 sec. runs LOL....
Just waiting on the 04's
