rear speakers: best practice for installation?
I have searched and found some good advice for the front set in the door panels, but didn't really see anything concerning the rear sets. Does anybody have experience with this or is there a install guide that someone knows of that details the best practice for replacing the rear set?
Thanks in advance.
Thanks in advance.
It's pretty straight forward. I installed Infinity Kappas all around. THe 5x7's in the rear corners....Ran them through the crossover on the amp to use for bass fill with the sub. 6x9's shouldn't be a problem....seems like someone said it could be done easily.
MMM, what I was hoping for was a sort of "guide" to removing the panels and such to get at the rear speakers themselves. I purchased the Infiniti's tonight and I am ready to go. Got them for $99 a pair. It would be nice to know if there was a pretty straightforward method (I would have never guessed it would be so simple to remove the door panels!!!)
slightly depress the center of the black push rivets...do not force all the way through. pull out as you push and you'll see that they come out in one piece. Take the corner uppper out..just pull on it...snaps into place.....same as the lowers....the speakers are just like the front ones...4 screws.....
Oh take out the shoulder harness upper bolt after unsnapping the cover. This makes things much easier.............This is from memory..so...it should be close.
