First installation pic
Old Dec 17, 2001 | 11:35 PM
PrinceVegeta's Avatar
I know its not an L but its going in the L when i get it in Febuary.
Just thought i would see what you guys think.It is my first install but will do more in the L then in this junker its in now(Stereo is worth more then car). I made it so it would be easy to take out.
Pioneer DEH-P9300
Infinity Kappa perfect 6.1
Infinity Kappa perfect 12"
MA Audio HC1002 for sub
MA Sudio HC502 for components
Planet Audio PC4 crossover
Phoenix Gold Zeropoint wires
Monster cable interconnects
Old Dec 17, 2001 | 11:54 PM
whitetoast11's Avatar
my own opinion,, you got ripped off if your amp didn't come with a good enough cross over as it is, i'm a little confused at this, i beleive that head unit has a built in cross over, the amp should have a built in cross over as most amps do, if this is the case then whats the nead for a third one. Also in the pic those look like capaciters you are running attached to your box,, what brand and what type did you pick??
Old Dec 18, 2001 | 11:05 AM
The HU and the amps have crossovers but i wanted a better one then the ones that it came with built in, especially for how much power i was putting into the speakers. I could of used the ones that were built in, and i did for about a week but i noticed at high output levels therewas some cancelation from the door speakers and the subwoofer playing the same fequencys around 80hz.So i needed somthing that had a higher octave crossover so i got the Planet audio one since it had 18db crossovers. And that crossover can also act as a line driver so i can turn up the voltage output to my amps at the crossover. The caps are Lightning audio, one for each amp.
